Question about Car Audio & Video
Hi guys i got Fusion EN AB2120 subwoofer and no idea how to install it in my car i already have bunch of wires in car but dont know wich wire gose where can anyone please help me out thanks
mixmaster
  • 626 Answers
SOURCE: wiring car sterio
Could not find your specific model.
But I found this on the Sony website.
9-pin wiring harness
16-pin wiring harness
Posted on Nov 25, 2007
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
jpenn1192
  • 58 Answers
SOURCE: how do i wire up fssion en at110 to stereo with NO rca outs
WHAT U WANT TO DO IS GO TO A LIKE BESTBUY OR CIRCUIT CITY, AND ASK THEM FORM A RCA CONVERTER, THEM SHOULD HAVE WHAT YOUR LOOKING FOR, THEY CAN ALSO RUN ANYWHERE FROM $10-20.
Posted on Oct 26, 2008
  • 18 Answers
SOURCE: replacement Kenwood KSC-WA82RC Car Subwoofer remote control wire
It looks like the S-video you need one end to be male and the other is female end.The high quality the S-video wire the better the sound.Make sure you get a long enough cord. Take it with you to radio shack or and car audio or home audio find the female end of the S-Video and it should plug in perfect.Wire it up and enjoy some tunes
Posted on Mar 03, 2009
etirbynnor
  • 655 Answers
SOURCE: dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Posted on Mar 28, 2009
I have a fusion en-sw12es that i am not getting any sound out of
Check the connection to the speaker first if not that then, check the connection to the head unit, inspecting the wire also, make sure both negatives and positives are aligned, if its none of the above might have a bad output on the deck or the speaker can be a dud.
Jan 21, 2011 | Fusion EN-SW12ES Car Speaker
Hi i have fusion sub woofer can u help me to install just let me know how to install many wires so dotn know who to install in my car
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Jul 06, 2009 | Fusion FEW12PK Car Subwoofer
Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Dec 09, 2008 | Fusion FEW12PK Car Subwoofer
How do i wire up fssion en at110 to stereo with NO rca outs
Oct 26, 2008 | Fusion FEW12PK Car Subwoofer
Sub making noise without input
Hi there guys, i dont have this problem ,but i do have the EN-AT1100 encounter 10" and cant get the thing to work at all. The six pin plug for the power (12V+), earth (GND) and accesories (REM) are all muddled up as i never bough it with the original leads. Can any of you help me out with the wiring on how to connect it? is there two wires for (12V+), two wires for earth (GND) and just one wire for accessories (REM)?
Hope you can help thanks.
Sep 13, 2008 | Fusion FEW12PK Car Subwoofer
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
Amplifier problem
Check your grounds, and all of your wiring. Does it just shut off or does it blink and go into protection mode?
Dec 01, 2006 | Fusion FEW12PK Car Subwoofer
Car Audio & Video Logo
225 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
