Question about GE GSS22JFMWW Side by Side Refrigerator
Side by side refrigerator stopped cooling. Temp was 55 degrees in fridge when I noticed. Vacuumed back and between coils underneath. Removed lining in freezer and melted heavy frost and ice build-up with hair dryer. Temp went back to normal for almost 2 days, then temp began climbing in fridge again. Replaced thermostat per youtube video (desperate finances forced me to try this). This was just last night, this morning I see frost build-up on coils and themostat, wires, etc. Is a little bit of frost normal, or am I still in trouble here? Any help will be appreciated-I am an old lady with no skills to do this stuff, but desperate enough to try. Thanks
  • GE Master
  • 43,501 Answers
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 24, 2011
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
We have a side by side samsung fridge/freezer. The freezer is working fine but the fridge is up to 60. We pulled the fridge away from the wall and cleaned underneath and also removed the grate in the...
One of the biggest problems is with the new refrigerants (R134A in this case). If the unit gets overheated it actually causes the salts in the moisture releases and travels throughout the system eventually clogging the metering device (capillary tube). The only thing that can be done is to have the system flushed, new drier, evacuated and re-charged.
Then make sure there is enough air circulating and keep the coils squeaky clean.
Nov 29, 2010 | Refrigerators
Freezer works fine, refrigerator does not cool. I vacuumed coils on the outside back, the fan in back is blowing air out, the freezer had a thin layer on ice which I removed and the temperature in the...
make sure the baffle leeding to the refrig is not blocked by food.
could be temp control for the fridge is bad when in doubt contact a professional its cheeper then buying the wrong parts.
If you need a part i reccomend www.appliancepartssolutions.com cheepest parts i have found...good luck
Jan 16, 2010 | Jenn-Air JCD2389G Side by Side...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Nov 28, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Maytag side by side fridge makes vibration noise
Mine is a different model, and less than three years old, but the vibrating noise was really annoying. I would shift the unit or the door slightly, and it would stop for a while, as you reported. I took a few minutes, applied pressure to different areas, up and down, inside and out. The noise was louder near the floor. I removed the plastic grill and applied upward pressure on the wires covering the coils - it was loose. I noticed an accumulation of dust, and vacuumed as far as I could reach around the underneath area; also pulled fridge out and vacuumed a dust-covered vent on the back near the floor. Was planning to insert some kind of wedge under the loose part, but when I put everything back in place, the vibration stopped - now I only hear a gentle hum. Seems I did something right in this process.
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot point side by side
Could be stuck in "defrost" mode. Happens a lot. See if you can hear if the compressor is running or the compressor cooling fan is running (in back underneath the unit). Worse case is the refrigerant leaked out and you have a sealed system problem.
Sep 28, 2006 | Hotpoint FFU00 Side by Side Refrigerator
GE GSS22JFMWW Side by Side Refrigerator Logo
295 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
