Question about Technics SL-1200MK2 Turntable
My pitch control goes slow when u push it up to - but goes even slower when u push it down to + is it nackered please help thank you Emmalene
    Problem Solver:
  • 5 Answers
You can try to recalibrate it by using the potentionmeter or 'pots' as they are sometimes called. There are two of them. One is on the main circuit board and one is on the pitch control. Either way you will have to take it apart to get to them.
Important*** When you have the platter off, do not hit the start/stop button!! This will ruin your motor.***
The easiest thing to do is order a new pitch control. They are relatively inexpensive and they are easy to replace.
Posted on Apr 15, 2011
Can you get a foot pedal for this machine that goes slow for beginners?
not needed just do not push down all the way . putting a door stop wedge between the top and bottom could help a lot
Nov 22, 2017 | Sewing Machines
Go Chair goes slow
check the breaks are not sticking on.
slacken off or remove to try if this is the fault
Jun 02, 2013 | Pride Mobility Pride Go-chair Travel Power...
When slowing down high pitch noise Hyundai i30 2011
your drivetrain is screaming already. Hope for the best.
Jul 20, 2012 | 2011 Hyundai i30 1.6
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 | Watches
99vw beetle gets really loud past 40mph, like a
Sounds like something is caught up inside or outside the engine/transmission where a part is grinding from something reciprocating. Does the sound happen when you apply the gas without the car moving? If the sound only happens while moving then it could be suspension or transmission related. If it only happens with or without the car moving as long as you control the gas then it's probably in the engine or transmission related. Could also be a wheel bearing issue, that will be a humming sound inside the cabin. As you speed up the pitch increases and the opposite happens when you slow down.
Nov 22, 2009 | 1999 Volkswagen Beetle
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Broken pitch control
Yep, time to replace the pitch control. You can attempt to do this yourself, however good soldering skills are required (not the time to learn). You will have to desolder the old pitch control, and solder on the new one. Which is why I say, now is not the time to practice soldering on your turntable. You could actually cause more damage.
If after replacing the pitch control, you still have the same issue, then there is something wrong with the drive on the unit. The drive is controlled by various integrated circuits (IC's), and they are known to short out every now and then. The problem is isolating the correct IC. FYI, Technics is starting to discontinue parts, and 1 of the main IC's on this unit is no longer available (IC302 - Nand Gate).
You can order the PITCH CONTROL HERE.
DJ PRO LAB
www.DJPROLAB.com
Apr 06, 2008 | Technics SL-1210 Turntable
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
Apr 01, 2008 | Technics SL-1200M3D Turntable
Technic's 1210M5G problem with the pitch slowing
Sounds like your pitch control is about to go bad. I would suggest replacing it. The part can be purchased HERE.
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 25, 2008 | Technics SL-1210M5G Turntable
Technics SL-1200MK2 Turntable Logo
63 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
