Question about Kenmore 65234 Bottom Freezer Refrigerator
Not cooling, fan works, lights work - Kenmore 65234 Bottom Freezer Refrigerator
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 24, 2011
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
1995 Camaro V6 3.4L Electrical Issues
Did you check the cooling fan relay's ? Your vehicle has three of them . Free wiring diagrams at http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click on engine , then under subsystem click on cooling fans . Then click the search button then the blue link . Learning how the fans work then testing the electrical circuits is how we as Technician solve problems like this . We don't ask if anyone has this issue an knows how to solve it . Someone else's fix maybe different from what it will take to fix yours .
The cooling fan's are computer controlled ,by the PCM - powertrain control module . When the engine coolant temp. gets hot enough the PCM see's this through the use of a coolant temp. sensor . When it reaches 212 degress the PCM energizes relay # 1 sending B+ voltage through both cooling fans to ground causing low speed .
Relay Driven Dual Cooling Fan Diagnostics
Aug 23, 2017 | 1995 Chevrolet Camaro
Chevy Impala 2003. Replaced cooling radiator cooling fan. Fan now works (driver side). Hooked up code reader. Received code for cooling fan removed code because fan was replaced. Next day engine light is...
is the passenger side coming on? it is possible that it is setting the code for different speeds also. may want to check the cooling fan relays.
Aug 03, 2011 | 2003 Chevrolet Impala
Which fuse goes to the cooling fan
there is fuse and a relay for the cooling fan.just turn ignition on and test all the fuses(some fuses will only work with the system on like headlights/tail lights).check the relay in the relay box(panel)under the hood.you may have a bad cooling fan,you don`t say why your checking the fuse.if you unplug the connector at the cooling fan and jumper a ground wire and power wire it should work.if not then you need a cooling fan motor or assembly.
Mar 22, 2011 | 1987 Pontiac Firebird
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
The Unit does not cool. The fan, lights, etc run
check if the compressor working if it working and you get frost in your freezer back panel then your problem is in your freezer area but if your compressor not working then and the fan next to it working then the starter unit for the compressor is bad....let me know if you need more help
911service today . com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
The cooling fans stop working
check your sensor that controls the cooling fans.may need to be replaced.
Jan 01, 2010 | 2003 Chevrolet Impala
2000 jimmy a/c blows hot computer controlled a/c button light was blue when working now yellow and blowing hot just charged system no change
check to see if ac compressor is turning ,if so look to see if cooling fan/fans are working if not check fuses,and cooling fan relays/if ac is turning and cooling fan/fans are working ,need to put gauges on ac system and check pressures ,if normal ,and ac low side pipe/lines/hoses are cols then it is ur actuator motor for the temp door that is not working
Jul 08, 2009 | 2000 GMC Jimmy
Kenmore 65234 Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
