Question about Nikon D3000 Digital Camera
Camera just turned off and wont come back on. Charged battery and no change. LED light still flashes when putting SD memry card in .
    Champion:
  • 226 Answers
Hi, sure main PCB damaged, contact Nikon service best way.
Regards
Posted on Mar 24, 2011
Is there another way to charge the camera so that I can turn it on and retrieve what is on it?
You will need either the camera power supply or a charged battery, if don't have a power supply for camera or a charged battery there is no way around it.
Jan 02, 2015 | JVC Everio GZ-MG30 Camcorder
What can I do to fix my phone it has white screen can not see anything
It doesn't sound too good for your phone. If it's an iPhone you can try to restore it. It sounds like it's just broke and time to get a new phone.
May 09, 2014 | straighttalk.com
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Switch sim card
Your SD card is for your memory check your battery
this is what you check... turn off your camera Take out you battery charge and replace... Take out your SD card replace it correctly. Remove your lens and replace correctly then turn on camera and walla it works! PS its ok to leave the SD card in the camera. The on and off switch turns on camera with a charged battery ELEMENTRY WATSON.
Nov 19, 2013 | Nikon Cameras
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
LED flashing green and red
I had the same thing happen to me with my pentax optio. You may have to large of an SD memory card. Or you could have the wrong type of card. I would recomemd that you use a 512mb SD card. Not the SDHC card. Also i would make sure that the battaries are fully charged. Hope this helps you out!
Jan 28, 2012 | Pentax Optio E10 Digital Camera
I just got my Nikon D3100 and it wont turn on..why?? i didnt buy a memory card yet..doest it need memory card to turn on??
The battery ships in an uncharged state. Slip the battery into the charger until the it indicates it is fully charged. Install into the camera. The camera should power up without an SD/SDHC/SDXC type memory card installed - and should flash [-E-] in the viewfinder alerting you to the fact that no memory card is inserted.
Sep 06, 2011 | Nikon D3100 Digital Camera
PLEASE HELP.
someone595,
Don't panic, keep in mind to turn off the camera before you remove the SD card or change lenes. Charging the battery shouldn't take too long put it back in make sure the lens is properly locked in place, put in the SD card in then turn it on and you should be good to go. let me know I'll check back in an hour to see if that helped.
randy320sgi
Jan 06, 2009 | Nikon D70s Digital Camera
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Nikon D3000 Digital Camera Logo
95 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
