Question about Motorola Mobility Rival A455 Cell Phone
My touch screen is too sensitive - Motorola Mobility Rival A455 Cell Phone
Evedure heater difficult to turn OFF. Touch panel doesn't seem sensitive any more.
Spray glass cleaner on a rag or paper towel..not on the touch screen...wipe the touch screen down and clean it. Touch screens often build up a layer of the oils on our fingers which then traps dust and dirt making them less sensitive.
Aug 09, 2016 | Heating & Cooling
We're is the LCD located in my phone
One of the iPhone's greatest features is its highly intuitive touch screen.
Unlike other electronic device touch screens, your iPhone doesn't operate using the blockage of light to decipher which keys and commands you're pressing.
This makes it a viable choice for cell phone users who may not be able to complete other types of commands.
While you cannot alter the sensitivity of your iPhone, you can toggle certain features that make your phone easier to use.
How It Works
The key to understanding the sensitivity level of your iPhone's touch screen is first understanding how the touch screen actually works.
Instead of detecting light blockages or heat to interpret your finger's movements, the iPhone actually has a grid that lies underneath the surface of the touch screen.
When your finger touches the screen, electrical impulses detect the area on the grid that you're touching to interpret the letter, command or motion you're making to issue the correct response.
Screen Sensitivity
While previous models of the iPhone did offer the ability to change the screen sensitivity and the speed by which your phone responds to commands, the iPhones 4 and 4S no longer offer the option.
Instead, the touch sensitivity on newer phones is automatically calibrated for the fastest speeds, which means your phone responds quickly to your touch.
If this frustrates you and results in commands and calls you didn't mean to make, locking the screen by pressing the button on the top right-hand rim of the phone helps stop unwanted commands.
Assistive Touch
Update iPhones running on iOS 5 with an option known as "AssistiveTouch," which allows users who may not have complete control over their bodies and motions to use the iPhone.
This program allows you to change the speed at which the phone responds to your touch.
By tapping the "General" icon, then touching "Accessibility" and "AssistiveTouch," you'll enter the assistive touch menu.
When you turn on the option, an overlay appears on the screen that allows you to give commands by touch, rather than by shaking, swiping or pinching the screen.
When setting up AssistiveTouch, you'll have the opportunity to select your command tracking speed, which deals with how sensitive your iPhone is to your various gestures and custom commands.
Case Issues
Your touch screen isn't the only place where your phone is sensitive to movements.
Your iPhone has a feature called a proximity sensor.
The role of the proximity sensor is to sense the closeness of your face during a phone call. When the phone senses that your face is close to the phone, it locks your screen to prevent you from accidentally activating the touch screen with your cheek or ear.
This is handy, except when the proximity sensor is partially obscured by a case and is no longer sensitive to the position of your face.
The proximity sensor is found on the upper right-hand corner of your screen, so ensure that it remains uncovered to preserve its sensitivity.
http://www.gadgetvenue.com/how-the-iphone-touch-screen-works-02223447/
http://www.appleinsider.com/articles/11/07/11/inside_apples_ios_5_assistive_touch_allows_accessible_gesture_commands/
Jul 14, 2013 | Cell Phones
Touch screen lost sensitivity
you need to order the lcd and touch screen to fit your problem.
has a look here.
Jun 26, 2013 | Apple iPhone4 4G iPhone 4
My touch screen is not working frequently. Give me the solution? How to restore my phone when touch screen is not working
Hello there,
If your touch screen is not working frequently, what you have to do is to calibrate the screen or check for the touch screen sensitivity. To calibrate the screen, go to the menu of the phone and select the settings, from the settings select the screen option, then you select calibrate screen and follow the rest of the instruction there on, or you select the touch screen sensitivity and increase it from there.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Nokia 5250 Cell Phone
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
How do i change the sensitivity on the behold 2 so that i can text with my nails?
Unfortunately this particular touch screen uses the heat sensitivity from your fingertips for the screen to work, like the iPhone or iTouch. A lot of the newer touch screen phones are like this now.
Apr 02, 2010 | Samsung Behold II SGH-t939 Smartphone
Screen sensitivity is low
try to clean the screen with the cloth inside the samsung box... its great so your screen will become sensitive
Jun 28, 2009 | Giorgio Armani Samsung P520 Cellular Phone
Instinct M800
Touch Sensitivity
1. Press Home > and touch Main > Settings > General > Touch Sensitivity.
2. Touch and drag the slider left or right to adjust the sensitivity level.
_ Touch the onscreen Touch Here button to gauge the response of the new sensitivity level.
3. Once you are done, touch Done.
Jan 17, 2009 | Samsung Instinct Cell Phone
PPC 6700 Touch Screen Sensitivity Changed
Realigning your screen might fix your problem. Settings -> System-> Screen > align screen.
I hope this helps
C
Dec 14, 2007 | Audiovox PPC 6700
Motorola Mobility Rival A455  Cell Phone Logo
168 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
