Question about Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
Circuit board failure - Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Posted on Mar 06, 2014
What do I need to do to fix a blank screen on a whirlpool built in oven?
Often the Whirlpool built in ovens have a control board failure which causes the screen to go blank. May be intermittent and may be accompanied by an E6 F2 failure code on the display (before it blanks out). We rebuild a lot of control boards for this problem. For example see:
http://www.fixyourboard.com/boards/8302967.html
Mar 18, 2015 | Whirlpool Ovens
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
Oven not heating and snds F3 error
F3 means the temperature sensor is open circuited. Which could be caused by the sensor itself, wiring to it or a failure in the control board. If it turns out to be the control board, we rebuild these which can save you some money. fixyourboard.com
Jun 29, 2010 | Kenmore 30169 Electric Single Oven
Whatt is an F1 fault on the kenmore stove
HI, This code is indicating that the main control board has failed. This will require you to have the damaged circuit board replaced, asap. This type of damage that has occur, is not repairable. The board must be replaced.
F-1 - Board Failure.
Dec 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Fault code 01 what is it / how to correct?
HI. Essentially, this code will indicate that there is a serious issue with the main control board. Try to reset this board. This can be done, by shutting off the power for five minutes. You can unplug, or shutdown the appropriate circuit breaker for this length of time. Once the five minutes have passed, simply, re- introduce power to the unit, and try to operate normally. If the error code returns, after the reset, kindly replace the damaged main circuit board.
F-1 Board failure. Replace control board (also called ERC or clock).
Dec 09, 2009 | Whirlpool Ovens
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
One more question
The electronic control board will have to be replaced. You can search online or call Sears (they can order just about any type of part for any type of product for you) with a model and serial number. Generally, the electronic control board is not that difficult to replace.
Jun 09, 2008 | Ovens
Dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Sep 04, 2007 | Ovens
Smeg F170 Pyrolytic Stainless Steel Electric Single Oven Logo
127 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
