Question about Vicks V150SG 1 Gallon Humidifier
When I first got the product, it worked great. Now there's hardly any steam coming out.
    Master:
  • 403 Answers
What is your water quality like. Anyway, unplug, and remove the screws from the underside of heating element. Pull unit apart and clean the heating coils, gonna have to scrap them with a utility knife. If you have hard water, deposits will build up on them , check them once a week if useing often
Posted on Mar 24, 2011
HE440A Steam Power Humidifier
The most common cause of overflow is when hard water deposits build up and prevent the float from closing. You'll have to open up the unit, make sure there's no water in it, and clean out any mineral deposits.
The problem with these steam producing units is that there is no built in way to remove those deposits automatically. The water comes in, evaporates, and leaves anything else that was suspended in it behind.
Nov 14, 2007 | Honeywell HE440A1005 Humidifier
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I have hard water, plugged it in, no steam. Added salt, no steam. What to do?
I have hard water as well and I wasn't getting steam. I put in a good tablespoon of salt and the steam started immediately. Try more than a pinch (if that's all you put in originally)
Oct 16, 2012 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do you fill with cold or hot water for vicks warm steam humidifier
im pretty sure you fill it with cold water...at least thats the direstions for when you use the vicks medicine you can add in...works great by the way
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
On/Off function
the kitty will turn off if you rotate the dail all the way to off (straight up). Look at the pink arrow on the dial. You will feel that the knob does not want to go any further when you are at "on" which is the lowest setting and no steam comes out. But you have to go all the way to off.
The elephant and frog models have actual on/off switches but this one its just the dail.
Apr 21, 2008 | Crane Hello Kitty Humidifier
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Vicks V150SG 1 Gallon Humidifier Logo
241 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
