Question about Samsung SGH-T519 Cellular Phone
I changed the language by mistake while navigatig the menu. I want t get back to the original English, which I could not do because all was in sme other language. How t get the original setting?
  • 492 Answers
I can think of one way. In the chat menu in Google you can chat in differnet languages so you might be able to interpret the menu on you handset that way. You might also find a friend who is familiar with both the idiom and menu on your phone.
Posted on Mar 24, 2011
  • ravivarma81 Mar 25, 2011
    Thanks. Let me look for a friend. Wonder why Samsung in the manual has not specifically given directions for this.
How do I change a language?
Change language on what? Go to the menu and select English. If you can't figure out the menu because of a different language then go onto your computer or laptop and find Google Translate and type the words into there to decipher.
Mar 08, 2015 | Hipstreet EQUINOX 2 10.1" Wi-Fi Capacitive...
Sir,I have motorola w200 cdma phone by mistake i have change it language and now i can't change its language please tell me how we can get english language.
Service codes Motorola CDMA: w150, w150i, w170, w170c, w200, w210, w355:
Set English language:
1. Menu
2. Down 7 times, Right soft button
3. Down 3 times, Right soft button
4. Down 1 times, Right soft button
5. Down 4 times, Right soft button
6. select language now
Aug 14, 2010 | Motorola Cell Phones
Hello i use nokia 5130 xpress music by mistake i
follow the menu numbers in upper right part in english, upper left in arabic. to go to language settings to english go to Settings#7, then Phone#11, then laguage setting #1, then Phone Laguage#1, then choose the language pack #1 is usually automatic that why maybe it chose arabic depending on your region. English is usually #2.
Jun 27, 2010 | Nokia 5130 Cellular Phone
My mobile is in different language, how i can make it english language
Was it or did someone change it recently by mistake? If you can at least read the language that would be very helpful.
If it was changed by mistake, simply follow the instructions;
(you have to look at the icons to locate all these) Menu > Settings then press up key once and press "Ok" again "Ok" and enter 12345, then "ok", now your phone will restart itself or it'll restore to it's original settings.
If this isn't helpful for you.. do like this...
Menu > settings > press down key 5 times and select it, the you'll see the lists of languages, use you up or down key to locate english which is written english "English" and select it.
Good luck.
Thanks for using FixYa.
Jun 21, 2010 | Nokia 5310 Cellular Phone
How to get my language back to english
Select your language.
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Language setup
After trying on my own, I went back into setting by scrolling along until a picto gram - with what appears to be a machine bolt is highlighted and then pressed SET - next the screen shows a bunch of chinese words (these are the different languages) then I scrolled down to the last one - until its highlighted, - this is the english one - press the set button on the side of the frame, this will bring you back to the english menu.
Dec 26, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Language change
Turn ipod on and hold the menu button for 1 second. f57f6a7.png  Scroll down 4 options until you get to settings.  Scroll all the way down to language which is 2 from bottom. From here you should be able to find the language you want.  English is normally the top option.  hope this helps ;)
Jul 19, 2008 | Apple iPod nano
Changed language to french!
Jan 01, 2008 | Apple iPod nano
first, press the menu button on the click wheel until your screen goes to the home screen (main menu). you will know you're there when the screen doesn't change anymore. select Reglages, then Langue, and finally English.
Dec 18, 2007 | Apple iPod nano
Language set up!
Go to the main menu and select the one with the volume picture which is settings. Then select the fourth one day the list which is language. Select the first option on the language list, it should be english.
Dec 01, 2007 | SanDisk Sansa c200 MP3 Player
Samsung SGH-T519 Cellular Phone Logo
144 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
