Question about Mitsubishi WD-73833 73" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
  • 917 Answers
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Posted on Mar 24, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
Bright white spots on mitsubishi wd-73833 because DMD.
below is example for worst bright dots. If your case like pic below, change DMD.
  • 167 Answers
Call Mitsubishi at 800 332-2119 with your TV model and serial number and they will set you up for a service call with a local TV Repairman which they have certified to install the DMD chip as per the factory instructions. The cost ends up half price and the TV looks better than when you first bought it due to the new and improved DMD chip. This has especially been an effective solution in the Tulsa,Ok and surrounding counties area. Even in Kansas, Missouri and Arkansas areas as well. The normal cost is about $425 and your cost is a flat $200 plus some mileage costs in some instances.
Posted on Nov 10, 2012
    New Friend:
  • 3 Answers
To fix mitsubishi wd-73833 DLP TV white dot issue, replace a new DMD chip following the post.
Posted on Apr 25, 2013
What is dmd?
Posted on Sep 24, 2012
  • Raj Patel Sep 24, 2012
    DMD stands for Digital Micromirror Device. It is part of the DLP board. Essentially, the microcontroller on the DLP board processes the reflective angle for each pixel required on the screen and moves the mirrors on the DMD accordingly.
  • drama42
    drama42 Dec 30, 2012
    I have a wd-60735, its 2 1/2 years old and the spots came up about 3months ago. I replaced the lamp year ago. I can't afford another tv. i pray that when I call the 800 # they will help me also. It's not right for us to purchase tv's and when you have problem you have to go through so much just to get it fix. EASY BUYING BUT H---- GETTING IT FIX!!!!
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
White spot on mitsubishi wd 73736 dlp
need to replace the dlp chip under 200.00
Aug 28, 2013 | Mitsubishi WD-73833 73" HDTV
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have White and black dots on the screen of my Mitsubishi wd-73833 tv.
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Jun 17, 2011 | Mitsubishi Televison & Video
I have a wd-73833 when i turn on the tv the front blue lights come on after a minute the tv turns itself off, there is no picture
I would check your lamp 1st. Do you have a lamp light flashing on the front of your set after TV shuts down? That is a message to let you know what might be wrong.
Apr 05, 2011 | Mitsubishi WD-73833 73" HDTV
My TV picture is starting to have a noticable flicker. Could be the lamps going out? If so how are they changed? Is this something I can do?
Take the TV apart. Have the lamps ready and use gloves to put the lamps in place. Never touch the lamps with bare hands because sodium will degrade the quartz lamps.
Aug 26, 2010 | Mitsubishi WD-73833 73" HDTV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
Great sound no picture
lamp needs to be replaced.
Apr 16, 2009 | Mitsubishi WD-73833 73" HDTV
Mitsubishi WD-73833 73" HDTV Logo
4,875 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
