Question about Vicks V150SG 1 Gallon Humidifier
Why is it "spitting" water instead of steam ?
The vaporiser is "spitting" out water, instead of a steady steam.now what ?
    Genius:
  • 1,027 Answers
If spitting, the resevoir is too full.
Posted on Aug 03, 2008
    New Friend:
I'm upset. Mine is 2 days old and my son is sick and I don't have time for this stupid thing to be sputtering hot water all over the nursery. I should not have to clean it after ONE USAGE!!! I feel furious about it.
Posted on Nov 21, 2013
3 Suggested Answers
SOURCE: Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Posted on Dec 07, 2008
Have you cleaned it recently? Sometimes that's an indicator that it needs to be cleaned.
Posted on Oct 29, 2008
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
How to stop humidifier from spitting out water
Humidifiers, depending on brand will spit out a little water as that is the Idea to get moisture into the air, but you can try not filing it so full, this one is steam so I would look into owners manual as to how to clean it , you may find that it has collected calcium deposits not allowing it to vaporize the water properly.
Mar 02, 2015 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I was given a Vicks Vaporiser model V188, no box, no instructions etc. I just assumed you filled it with hot water & put eucalyptus oil in the water & plug out in the wall & that's how it worked. Now that...
vaporisers are a great way to make your home a healthier air environment , first id like to caution you on what you add to your water feed , b sure it doenst contain any chemicals that might degrade in heating to be toxic to humans , example( air fresher's) these contain sometimes propane as a propellant and that shouldn't be added to live steam , read the labels on what u add to water ??? next im not sure why you couldn't breath in the steam , I do suggest you use a large bath towel and drape it over your head and hang it down over vaporizer to catch steam , this is safer than sticking your face over one directly also these machines do require weekly cleaning and do manage to get bound up with minerals that are in tap water left behind inside the unit , its best to keep a indoor air humidity of 70% rh in winter and summer for proper health , gauges for this measurement are cheap and easy to obtain
Mar 02, 2017 | Humidifiers
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Vaporizer shorting out the house power
could be faulty element or earth leak - as it is new - I strongly advise you to change it at the store you purchased it from.
Jul 21, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer is spitting water
You added too much salt. Clean it out, start over with less salt.
Feb 08, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Spitting noises and gushing water
Another alternative to vinegar is to use lemon juice. About 1 cup to a tank of water should do the trick. It smells much better than vinegar and also has the acid content to clean the vaporizer.
Jan 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks V150SG 1 Gallon Humidifier Logo
9,035 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
