Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak printer error code 3518 constantly on, have done everything recomended to no avail, i want to throw it through the window
Mykel_N
  • 315 Answers
SOURCE: kodak 5100 all in one printer, 3802 code
You need to contact kodak and ask for a replacement print head, explain the code and whats been happening.
www.kodak.co.uk or www.kodak.com
They will probably tell you to download new drivers and wash your printhead ect ect but nothing that helps.
I had the same problem with the same printer.
I couldn't get Kodak to send out a printhead, so after weeks of messing around, I took it back for a refund.
If you do manage to get a new printhead here are the instructions on how to remove and replace it.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Posted on Jan 31, 2009
  • 60 Answers
SOURCE: Cannot communicate with printer error
error codes that you mentioned are not related to your issue you will get those are for front access door open and main paper tray empty.........the number of times you open the front access door and when ever the main paper tray is empty you will get that error.......you mentioned that HP printer worked......i would recommend to use a clear utility for HP and remove all the drivers and software for HP first as that might be conflicting with Kodak and make sure the version of the software for the home center(which includes drivers) is latest which is 3.4.......you can check for the version of the software by opening the home center and click on the question mark on the top right and then click on i which is on the right in the new pane that comes up and you will be able to see the software version in the right hand bottom corner on the small window that comes up.......if you have the latest version of the software then make sure you have the latest chipset drivers on your computer......for that you can contact your system manufacturer.......i suppose you have Dell...........if that also does not help then just tell me what all options you have under the Universal Serial Bus Controller.........also make sure if you have printer icon in the printers and faxes in case of XP and under printers in case its Vista.......if not then try and add a printer icon........if you already have a printer icon then try and right click on it and set it as default printer and then check if it works............let me know whats the result and was this helpful or not..............
Posted on Jul 16, 2009
  • 295 Answers
SOURCE: I have a kodak esp9 on win xp wireless connection.
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Posted on Jul 28, 2009
SOURCE: Error code 1-2036 on Kodak ESP3 printer
To askmeprinter: following your recommended steps does fix the problem TEMPORARILY. The scanner will work after being re-installed, but will cease working again after going into sleep mode.
Posted on Jul 30, 2009
shockwave727
  • 262 Answers
SOURCE: kodak easyshare printer 5300 error code3501
3501 error code indicates that the printer access door is open(The door that you open to able to see the ink cartridges).
If you recieved this error code and yet printer access door is open try to reopen it and close it, then unplug the power cable of your printer for 10sec then Plug the power cable back.
You cannot do any task on your printer if you have this message 3501. if this isue not solve call kodak tech support toll free 1 800 421 6699
Posted on Nov 08, 2009
Kodak Printer ESP 3 Error Code 101-707 when installing driver
Try downloading/installing and/or upgrading the .net from microsoft first.
Nov 01, 2017 | Computers & Internet
Kodak 3250 printer (brand new) wont scan, issues an error 2005 warning??? Help. I've followed Kodaks troubleshooting instructions to no avail. I've also uninstalled and reloaded...nada, nothing...ziltch...
From Kodak's website:
Answer : To resolve error code 2005, 2006, 2007, 2008, 2009, 2036, 2105, or 2106:
1. Go to www.kodak.com/go/2005 to run SSEUtility.exe.
2. Do one of the following depending on your browser:
- WINDOWS Internet Explorer: Click Run, then click Fix.
- MOZILLA Firefox: Click Save, then double-click SSEUtility.exe.
3. Try to install the KODAK All-in-One Printer Software.
4. If the following message window appears, your processor supports SSE and the utility will not be able to help.
Click the X in the upper-right corner to close window.
5. If the problem continues or you were not able to use the utility, contact Kodak (1-800-421-6699)
Dec 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
What is an error 3807?
If this error is from your printer itself, This error code means that you need to replace the Printhead. Call Kodak so that they can process a replacement for you 1800 421 6699
Thanks
Aug 24, 2009 | Kodak ESP 5 Printer
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  3. Select Printers.
        • Click Properties.
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error installing startup disk net framework error
If you are installing from a disk... throw it away.. download the newest software from the web:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=13658/13661&product=EKN035328
Jul 08, 2009 | Kodak Office Equipment & Supplies
It only prints light color ive replaced branw new
You need a new print head. Don't buy one, though. Phone Kodak (India) and get a new head. Or throw the stupid machine away. Kodak should be sued for producing such poor quality ****.
Jun 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Perhaps this will help, universal error codes for the Kodak 5100 thru ESP 9 inkjet printers:
RME: Kodak
STATUS_OK_ALL = 0,
STATUS_OK_MANUAL_DUPLEX_STARTED = 97,
STATUS_OK_MEDIA_DETECT_STARTED,
STATUS_OK_FORM_FEED_STARTED,
* Informational (0100-0999):
* Busy (1000-1999):
STATUS_BUSY_SYSTEM_BUSY = 1999,
* Warning (2000-2999):
STATUS_WARNING_IMAGE_TOO_LONG = 2998,
STATUS_WARNING_IMAGE_TOO_WIDE,
* Asynchronous Ok (3000-3099):
STATUS_OK_MANUAL_DUPLEX_COMPLETE = 3000,
STATUS_OK_PAGE_EJECTED,
* Asynchronous Warning (3100-3199):
STATUS_WARNING_BLACK_INK_LOW = 3101,
STATUS_WARNING_COLOR_INK_LOW = 3102,
STATUS_INK_TANK_INVALID_MANUFACTURER_COLOR = 3103,
STATUS_INK_TANK_INVALID_MANUFACTURER_BLACK = 3104,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_COLOR = 3105,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_BLACK = 3106,
STATUS_MEDIA_VERSION_EXCEEDS_FW_VERSION = 3107,
STATUS_INK_OVERFLOW_EXCEEDS_CAPACITY = 3108, // Will be deprecated
STATUS_WARNING_BLACK_AND_COLOR_INK_LOW = 3109,
STATUS_WARNING_PROOF_SHEET_WRONG_MEDIA_SIZE = 3110,
STATUS_WARNING_PROOF_SHEET_WRONG_SESSION_NUMBER = 3111,
STATUS_WARNING_PROOF_SHEET_NO_IMAGES_SELECTED = 3112,
STATUS_WARNING_PROOF_SHEET_READ_ERROR = 3113,
STATUS_WARNING_MORE_THAN_1000_IMAGES = 3114,
STATUS_WARNING_INVALID_DPOF_FILE = 3115,
STATUS_WARNING_NO_IMAGES_FOUND = 3116,
STATUS_WARNING_SCAN_TO_OPERATION_FAILED = 3117,
STATUS_WARNING_BLUETOOTH_CONNECTION_DROPPED = 3118,
STATUS_WARNING_UNSUPPORTED_USB_DEVICES = 3120,
STATUS_WARNING_OVERCURRENT_USB_DEVICE = 3121,
* Asynchronous and Synchronous Error (3200-3499):
* Job Recoverable. No User Interaction.
// STATUS_PRINTER_BUSY = 3201, // not used. duplicated number
STATUS_INK_TANK_REPLACEMENT_IN_PROGRESS = 3207,
STATUS_PRINTHEAD_UNCAPPED_TIMEOUT = 3208,
* Asynchronous and Synchronous Error (3500-3599):
* Job Recoverable. User Interaction Required
STATUS_ERROR_UNIT_OPENED_WHEN_IDLE = 3501,
STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY = 3502,
STATUS_ERROR_PHOTO_PAPER_TRAY_EMPTY = 3503,
STATUS_ERROR_PAPER_JAM_DURING_PICK = 3504,
STATUS_ERROR_NON_PLAIN_DETECTED_DUPLEX = 3505,
STATUS_ERROR_MEDIA_SIZE_MISMATCH = 3506,
STATUS_ERROR_INK_OUT_BLACK = 3507,
STATUS_ERROR_INK_OUT_COLOR = 3508,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_COLOR = 3509,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_BLACK = 3510,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_COLOR = 3511,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK = 3512,
STATUS_ERROR_PRINTHEAD_NOT_INSTALLED = 3513,
STATUS_ERROR_BACK_COVER_REMOVED_WHEN_IDLE = 3514,
STATUS_ERROR_CARRIER_STALL_DURING_PICK = 3515,
STATUS_ERROR_MEDIA_LOADED_UPSIDE_DOWN = 3516,
STATUS_ERROR_INK_OUT_BLACK_AND_COLOR = 3517,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK_AND_COLOR = 3518,
STATUS_ERROR_PHOTO_TRAY_ENGAGED = 3519,
STATUS_ERROR_FAIL_TO_DETECT_PAPER_EDGE = 3520,
STATUS_ERROR_VOLTAGE_TO_PRINTHEAD_NOT_CALIBRATED = 3521, // Should only be used at the factory
* Scanner (6000-6299):
SCANNER_ERROR_ADF_PAPER_OUT = 6101,
SCANNER_ERROR_ADF_PAPER_JAM = 6102,
SCANNER_ERROR_MOTOR_LOCK = 6201,
SCANNER_ERROR_MOTOR_MOVE_FAILED = 6202,
SCANNER_ERROR_HOME_NOT_DETECTED = 6203,
SCANNER_ERROR_CALIBRATE_FAILED = 6204,
SCANNER_ERROR_ADF_SENSOR_FAILURE = 6205,
/* Internal used errors. to be removed */
STATUS_ERROR_PAPER_JAM = 3201,
STATUS_ERROR_CARRIER_STALL = 3202,
May 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak 5100 all in one printer, 3802 code
Jan 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Disconnected a lot!
Restart your computer. The AiO software will show "connected" on the main window, and you will be able to scan, corpy, etc. Once you close (x out) of the AiO software, then open it up again, the "disconnected" error shows up. The only way to use the AiO software once again is to (you guessed it) RESTART the computer. George Elvidge in NS
Aug 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
517 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
