Question about Toshiba 65H81 65" Rear Projection Television
Casias.com does not exist
I am looking for repair procedure for STK parts on my Toshiba TP55H95 rear projection TV. It has a blinking Power Indicator (red) light.
Your write up mentioned the casias.com site as reference for disassembly instruction. However it looks like that this site is no longer active. Do you know of an alternative site that can guide me on how to remove and repair the STK parts and R810?
Thanks,
Rob
    Problem Solver:
  • 6 Answers
Your STK parts might not be your problem for blinking red led. As I have read throughout other forums, the first think to address is your power deflection board .....that's the first one that goes. If it is the first time, it might be that only a couple of fuses on that board go bad, I had the same problem with mine, as I remember correctly, F850 and F852 were bad....I replaced mine and had tv for 12 months when a storm caused the whole power to go on and off a few times and screwed up my set and now more parts on power board are messed up. I'll replace mine in totality.
Convergence STK's will tell you when they go bad because you will notice something with your picture right before they give in. But in your case, you can't turn your set on.
Try to put your hands on info that tells you about codes on that blinking light. I tried to find that kind of info but I didn't try hard enough. I wish I have it, it could save me a ton of headache.
Hope this helped.
Nic
Posted on Nov 07, 2008
Tv stopped working and red light started to blink
this problem can be solve by changing the 2 IC of convergence. part # STK 392-110. It would take 30 to 60 minutes to open change and reclose.
Apr 23, 2010 | Toshiba TZ50V51 50" Rear Projection...
How much is a power board for a tp50h95/tp55h95
bluestar international has one for 145.00 and 13 s&h they have all you hard to get parts that repair guys overcharge for ,they take paypal too http://www.bluestar-online.com/SearchResults.asp?Search=STK392-040&Search.x=12&Search.y=16 search here for your parts
Jul 13, 2009 | Toshiba TP50H95 50" Rear Projection...
Power indicator blinks; but no picture.
Likely to be the STK convergence chips causing a protection circuit to cut in and switch the TV off when turned on. Do you hear clicking when you switch on?
Kelvin
May 28, 2009 | Toshiba 57H81 57" Rear Projection...
Have a toshiba model # tp55h95 tv. The power light is blinking
Something is keeping your power supply from starting up. Bad capacitor...most likely. Replac 'em all! They're cheap!
May 21, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes parts.
Good Luck.
Nov 03, 2008 | Toshiba TP43H95 43" Rear Projection...
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Jan 12, 2008 | Toshiba 65H81 65" Rear Projection...
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65H81 65" Rear Projection Television Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
