Question about Garden
What should be used for a fastener to an exteroir wall with tyvek and or blueskin?
    Master:
  • 403 Answers
You can just staple it up before you side the wall
Posted on Mar 24, 2011
Heavy duty construction adhesive
Ceramic is particularly difficult to bond to due to the polished surface. The shelf you describe is probably heavy, but you have no dimensions or weight provided. I see these shelves fail frequently when they are only "glued" to the wall. It should have been installed to the wall first with a bracket arrangement, then the wall flashed and tiled around the shelf (presuming you have tile walls).
I would recommend that you use stainless steel brackets fastened into the walls (may require using toggle bolts - be sure to run the bolt through the bracket first!) to support the shelf. Use brackets at each wall, then use silicone sealant over the fastener heads. Use the largest brackets that the shelf will allow, you might be able to just epoxy the shelf on top of the brackets rather than trying to install fasteners into the shelf piece, which might break it.
This vendor has nice stainless steel brackets:http://www.gsproducts.co.uk/stainless-steel-corner-angle-brackets/
Apr 19, 2017 | Home
Where can I get the 4 fastners to mount my TV on the wall...the TV is a SV47OM 2009 model and no papers
Almost any big-box hardware/home center store has a fastener section. Simply check the specs on the size and length fastener you need (many are metric), and you can get them from these places. The hardest part is usually trying to determine the size of fastener needed. It is often buried in the specifications section of the owner guide. For some strange reason Fixya thinks that the word "SCREW" is vulgar and won't allow it, so I uses fastener instead.
May 23, 2016 | Vizio SV Televison & Video
Broke my antenna for my coy tfdvd9389a/9189a for my car. the high powered one that magnetic for the exteroir of the car
Ideal that you must consult with an car accessories shop. You might be able to get a replacement or even one that matches.
Nov 12, 2011 | Televison & Video
Paper is jammed between rollers and rear paper entry how do I get to it
More paper (pick fluorescent colors if you can,) an LED crank flashlight, and maybe a tyvek spatula and/or a long thin blade or Philips #1 screwdriver. Mostly it's finding an opening....
Aug 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have ceramic (terra cotta) block walls in my basement (house was built around 1920. The blocks are ridgid and were not laid very evenly, although the walls are sound. Plastering is an option, but with...
My house is of similar age and construction. I built a nice TV room in the basement several years ago. My method was the same as the way interior walls are built in new construction. I nailed a 2x4 to the ceiling near the wall. I nailed another 2x4 (pressure treated) to the concrete floor directly below the 2x4 on the ceiling. Then I toe-nailed vertical studs in place. For the studs I used 2x3's since this allowed me to get a nice flat plane on the front surface while allowing an inch of space on the back for irregularities of the block wall. I then covered the studs with water resistant drywall. The results were excellent and have held up very well. I also use a dehumidifier, since my basement was somewhat damp. I built the dehumidifier into a cabinet so that it draws air from the space between the block wall and the 2x3 wall. I don't need to run the dehumidifier in the winter. For the interior walls separating the TV room from the rest of the basement (furnace and workshop area) I used 2x4s for the studs, but the 2x4 along the top and bottom were just like the first wall I described. And by the way, in order to nail the pressure treated 2x4 to the floor, I used a power-nailer that uses charges that look like 22 caliber gun blanks. This seems spooky, and is wicked loud (use earplugs and safety glasses!), but it is inexpensive and very effective. The nails don't have to resist pulling out, they only have to resist being slid around, since the wall stud holds the pressure treated 2x4 against the floor. Good luck!
Apr 07, 2011 | Drills
Error c620- I tried to copy on a piece of Tyvek (plastic paper) and it melted. I pulled it out using pliers and now I get this error message
are you sure it is 620? not 6020 or 6200?
try hitting 1087 two times on the keypad, that is maintenance mode now type 906 and start button or execute and start button. that will reset a fusing code. that is the only way to reset those codes for safety reasons.
Aug 04, 2009 | Copystar CS-2030 Copier
How to remove the extra tire.
The tools to remove the spare tire should either be behind the bench on the floor or wall, or under the rear seat (king or crew cab) in a trap door. The instructions for removing the spare are printed on Tyvek paper and should be zip tied to the tools.
Hope this helps!
Jan 06, 2009 | 1999 Chevrolet Silverado 1500
Licens plate fastener
you should have an access point in the trunk. if the plate is mounted on the trunk wall yopu have to pull back the fabric to gain access. if it is mounted on the trunk lid there should be an access panel you can remove to gain entry to the little cubby. just use a pliers to hold the plastic isert and remove fasteners. this should do the trick...please rate thanks
Sep 05, 2008 | 2001 BMW 5 Series
How to Install Toilet Paper Holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
Aug 27, 2008 | Hansgrohe E & S Accessories 40526000...
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
