Question about JVC Televison & Video
My JVC LT-32DG20J has started playing my Xbox360 and playstation2 in black and white. I have tried changing all the picture settings
  • 9 Answers
What AV connections are you using? some of the older composite cables will make your game systems play black and white on HDTV's. RGB connections are different than the old standard RWY cables.
Posted on Mar 24, 2011
JVC LT-32DG20J Flashing blue light and no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2016 | JVC Televison & Video
JVC LT-32N310a No picture
even if you change the source ? or you cant do that ?
http://www.tvrepair.localdomain.me
Jan 07, 2014 | Televison & Video
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
I have a JVC LT 32 EX 18 TV. When connecting my laptop over HDMI, playing on a playstation or WII the sound and picture work perfectly. When I want to watch normal TV over cable though the problems start...
If the rear inputs work consider connection for the channels with a box using one of the rear inputs--sounds like a tuner related issue and going to the rear inputs bypasses that.
Nov 07, 2012 | Televison & Video
JVC AV27S33 tv black and white
I would guess you are using an antenna or a cable service without a set-top box.
When the TV is using HDMI or component video it does not employ the decoding for the color as like when using an RF feed. Most people of today do not use RF directly in to their TV set using the built in tuner. They feed a desk-top box that feeds a decoded picture in to the set via the component RGB connectors, or they are using HDMI.
When viewing an RF signal from the antenna or cable using the TV's internal tuner, check the video settings. make sure the setting for Color is turned up to 50% of its range to start with. If there is no color, check to make sure the Settings are correct. Check to see if the TV has a black and white mode, and this mode is turned on.
Check to see if the TV receiver section is for your location type. If you have a set from another country that uses another broadcast system for color this can be an issue.
It is also possible the TV set's color decoder for RF reception is defective. This would require proper service. You would not be able to service this yourself.
Based on the info you supplied these are the best suggestions I can think of...
Mar 11, 2017 | JVC AV-27S33 27" TV
PAL 60 Display Problem
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/917304
Please let me know if you have any issues.
Regards,
Feb 12, 2010 | Microsoft Xbox 360 Console
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Why it's black& white?
the phillipines use ntsc m standard for tv broadcast, where were you using it before. Might be different. dont think you can change settings. its either one or the other
Mar 18, 2008 | Sony PlayStation 2 (PS2) Console
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
Televison & Video Logo
178 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
