Question about Sebago Docksides Shoes
Uppers are dirty, suade, how do i get them clean
Why do I get check upper thread on the screen
Perhaps the thread sensor is dirty and a good cleaning is in order.
Or the thread is not fully seated in the tension disk. When threading the upper thread, be sure to RAISE the presser foot during the process.
Apr 18, 2016 | Bernina Sewing Machines
Suad mouth appliances for sleep apnea reviews please about suad.
From my personal experience my dad was suffering from sleep disorders & this was confirmed by the doctor. Mouth appliances for sleep apnea will not going to help you, not even therapy or medication. The most common treatments for obstructive sleep apnea are dental appliances, CPAP machines, and surgery. Sleep apnea caused due to increase of obstacle or hindrance in the nasal passage which may lead to interrupted breathing during sleep. Sometimes weight loss can help , but not always. I will recommend you to use Asonor nasal spay to rid from sleep apnea and all your sleep disorder.
Aug 12, 2014 | Health & Beauty
Why are my dishes still dirty
Try adding some TSP (tri-sodium phosphate to your dishwashing detergent.
Aug 05, 2014 | Whirlpool Dishwashers
How to clean transferbelt in bizhub c220
Remove the transfer belt unit,remove the upper cover and used a vacum cleaner,cleaning under transfer belt cleaning belt section.
Jan 26, 2013 | Konica Minolta Bizhub C220 Color Copier
Outside of freezer on left upper side..it is very hot on the outside..the refrigerator is saying service as well..
sounds like the condensor needs cleaning and the service light is telling you its dirty . the unit runs too long when dirty and does not cool properly . also can cause or shorten the compressor life. mm p s clean . turn of power remove top cover and use a coil brush and vacuum .
Aug 11, 2010 | Sub-Zero 632 / S
How does lower and upper buckets work . is it the dirty water suppose to go in lower bucket or what . as i am trying to use this vac i am not able to
The Upper tank is for hot, clean water, with carpet cleaning solution mixed in at 5 ounces/gallon.
The Lower tank is the dirty water ecovery tank, hooked to the nozzle on the hood to **** up the water from the carpet.
Jan 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes still dirty after heavy wash cycle
There is a screen on the drain area of the bottom of the dishwasher that needs to be cleaned. It has a plastic mesh screen on it - you can't miss it. Second get an old toothbrush and clean out the little jets on the washing arms that spin around. You will notice these holes are clogged up with calcium deposits etc. Those things done you will have a new dishwasher again. You need to do this every 6 months or so. Also use a rinse conditioner for a while to assure the jets are clean. Good Luck
Nov 29, 2008 | Dishwashers
Sebago Docksides Shoes Logo
250 people viewed this question
Top Sebago Clothing Accessories Experts
john h
Bill Boyd
monetfoot wear
monetfoot wear
Are you a Sebago Clothing Accessory Expert? Answer questions, earn points and help others
