Question about Maytag MAH6700AWW Neptune Front-Load Washer
We just moved our Neptune front-load washer. There seems to be excessive shaking during the spin cycle - seems to be getting worse. Is there something we should check that may have gotten unbalanced during the move?
    Brigadier General:
  • 6,277 Answers
Absolutely!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 24, 2011
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our Maytag washer rocks violently during the spin cycle.It shakes the whole house and seems to be getting worse. We put shock absorber rubber mats under it but it just rocks off them.
Sorry to read about your problem, I hope this helps you out.
you must have a broken balance spring/shock on your machine...
I suggest you contact a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Shaking and moving washer
my washer shakes when its washing clothes
May 23, 2010 | GE WPXH214A Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Maytag Nepture washer shakes across floor
iff you remove the door assy 2 screws holding it on) andthe n the 2 screws opposite the hinge, youll be able to remove the front cover and look at the inner workings of unit, perhaps a shock absorber has broken causeing the vibration
Feb 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Trouble balancing a used neptune front load washer
It might not be the leveling of it. Front load washing machines have a lot of power when they go into their spin cycle. Depending on your floor and if the washer is upstairs it is going to shake and make a ton of noise. When I worked for Sears as a tech I had to explain this to a lot of people that just got their first front loaders. Some of them would say that it sounded like a plane was flying threw the house when it would spin. Others said it was like an earthquake. Front loaders don't work good in mobile homes either. Not saying that you have one. Anyway, when these go into spin the have so much force coming from them and all that force goes straight to the floor. If your floor is weak or that washer is in a spot where it is weak it's going to shake. The best thing to do is go under the house and put in a support beam right under the washer. This will get it to lighten up a bit and maybe even fix all together. Give that a try and see how that does. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
149 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
