When I turn on my tascam 2488mk there's a message that reads...Cannot book!! Not detect hdd correctly please power off and check h\w.
    Problem Solver:
  • 15 Answers
Well id say the hard-drive is not properly connected inside the computer to the motherboard. usually two cables that connect it one looks like a strip of mutiple wires usualy wide, and the other is a power cable that connects to the power supply. try removing the strip cable and reinserting it.
Posted on Aug 03, 2008
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
When I turn on my Tascam 2488 it says Cannot BOOT !! Not Detect HDD correctly Please POWER OFF And Check H/W
Secure the connection of the hard drive by pushing if firmly or
by pulling the connection, then reconnect it again.
Oct 05, 2010 | Tascam 2488 Portastudio Multitrack...
Where can I get knobs for a Tascam 2488 MKII. Trim knobs
I get a CAUTION sign when I boot up that says:
Cannot Boot! Not Detect HDD Correctly. Please POWER OFF , and Check H/W..." Can anyone assit me with resolving this problem
Thanks
Scott
Feb 11, 2010 | Tascam 2488mkii 24 Track Recording...
Cannot boot not detect hdd correctly power off and check h/w
Usual suspect is a faulty power adapter which is failing to provide enough power for the drive to spin up to speed. Try another adapter with the same ratings.
bd.
Jun 12, 2009 | Tascam 2488 Portastudio Multitrack...
HI I have the tascam 2488 mk11....have only had it a little over a year....has about 20 hrs. playing time on it as I haven't had time to use it.....Today it gave me the following message; CANNOT BOOT...
This is often due to the HD not getting enough power to spin up to proper speed when booting. Usual suspect is the power adapter. You might try picking up an after market one that matches the specs before going through the expense and trouble of shipping the unit back.
Feb 19, 2009 | Tascam 2488 Portastudio Multitrack...
The unit will not boot up.
Hi Jerry, I had that same message come up and like you I hadn't used the mkii that much...I was able to reach a tech at tascam and he gave me the following advice and it should reset the unit;.
Here's what he said to do; first you power off and then you hold down the following buttons;
quick rout button....shift button....send button...and the shut down button.....while holding down these 4 buttons turn on your unit.....when it says initialize..let go and hopefully it will reset....
Hope this helps JP
Jan 09, 2009 | Tascam 2488mkii 24 Track Recording...
Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Jun 19, 2008 | Tascam 2488 Portastudio Multitrack...
TASCAM 2488 won't boot up..HELP!
reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
Apr 09, 2008 | Tascam 2488 Portastudio Multitrack...
Check H/W?
sounds like a problem with the internal disk drive, could be damaged and may need replacing... if its still within the warranty return it for repair or replacement.
Nov 29, 2007 | Tascam 2488 Portastudio Multitrack...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
