I have a document in the memory of my Cannon MX300 Printer and can't figure out how to clear it. I have tried pressing the pause/reset button but to no effect. Help
  • 917 Answers
You can clear the printer memory by switching of the power and unplugging the printer from the mains socket. The problem may actually be that the Windows print queue is holding on to the document, in which case you need to remove the document from the print queue on you PC.
Posted on Mar 24, 2011
Oce cs2224 error code?
Try to reset your printer by pressing the "RESET" button... then try to reinstall the printer's driver in your PC or Laptop.
#NZ
Jul 28, 2014 | Cannon Office Equipment & Supplies
How to fax on the cannon mx300
Step 1:
Put the document you want to fax on the glass scanner.
Step 2:
Adjust quality and contrast to your liking.
Step 3:
Dial the recipients number
Step 4:
Press the "Color" or "Black" button.
After scanning the document press "Ok" to send the fax.
To do this you must first set up the Cannon mx300 for faxing.
More information can be found in its manual here:
http://www.copiercatalog.com/catalogfiles/PIXMA_MX_300_service.pdf
Aug 21, 2011 | Office Equipment & Supplies
Cannon MX340 printer - error code 6500
If the printer is not working properly or to clear memory try this:
1. On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Or Try This:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF.
Or Try This:
Reseat the printhead (printhead may also need replacing)
Aug 13, 2011 | Office Equipment & Supplies
Have a Cannon MX340 7 when trying to print the Alarm light blinks & message say Printer error 6500
this could be bad feed rollers... clean them with rubbing alcohol and a clean cloth...
if not then try
Or Try This:
Or Try This:
Memory is full. i don t know how to clear memory to fax
Here is your solution:
    • 1 Click the "Menu" button.
    • 2 Press the arrow buttons to scroll through the options on the screen. Select "MEMORY REFERENCE" and click "Start/Copy."
    • 3 Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
    • 4 Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
    • 5 Click "Stop" to finish.
To clear only some documents from memory, click "#" instead of "*" in Step 4. Follow the instructions to select the documents you wish to delete.
More can be found here:
http://www.ehow.com/how_7259282_clear-memory-canon-fax-machine.html
Jun 10, 2011 | Canon PIXMA MX300 All-in-One Printer
I cannot seem to cancel an old job stuck in there. I have hit cancel, powered off and on, unplugged. Everytime I try to print a new job it puts out this old one.
moz-screenshot.pngThe best thing to do is do a memory reset. But this could also clear pages and formats, user defined characters and fonts, configurations,tables,or all of these parameters.
To reset memory
1.Turn off the printer.
2. Set the DIP switches to reset a portion.
3. Press and hold the Feed/Pause button while turning on the printer. The printer prints out a hardware configuration test label.
4. Hold the Feed/Pause button for 1 second. The printer resets a portion or all of its memory.
5. To exit test and Service mode, turn off the printer.
6. Reset the DIP switches to their original setting and then turn on the printer.
That should do the trick.
Sep 13, 2010 | Intermec EasyCoder 4420 Thermal Label...
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Cant print using Canon Pixma MX300
Hi
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 08, 2009 | Canon PIXMA MX300 All-in-One Printer
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
Canon MX310
The thing is, in the back of the printer you have a column of jacks, the one on top has an icon of a phone and the one on bottom has a picture of an “L” or laptop. TAKE YOUR USB CORD OUT OF EITHER ONE OF THOSE, NO MATTER WHICH ONE IT MAY BE. What you may not have figured out by now is that there is a THIRD jack that is nowhere near those two. If you’re facing the front of the printer to the far right of the backside of the machine, there is this deep cavity that has your third, miracle jack in it. It’s even more to the right than the two jacks I described previously and its icon looks like a sideways, three-pronged cactus. Plug the square end of the USB cord into that jack, and the In Use/Memory light should stop blinking, and your printer can stop acting like car because the annoying, turn-signal clicking should stop as well. :)
Fame!.
Jul 05, 2009 | Canon MX310 Office All-In-One Printer
75 people viewed this question
k24674
jasbo
jasbo
