Question about Epson PowerLite® 83c LCD Projector
Image is upside down. ceiling option not available
  • 3,400 Answers
Yes there is the option for ceiling mount in extended menu - here's the manual section 16 explains
http://files.support.epson.com/pdf/pl822p/pl822pug.pdf
Posted on Mar 24, 2011
Image is upside down how do i turn image right side up
Go into the menu then the display option. It's probably set for "ceiling mount"
Nov 13, 2014 | Mitsubishi HC3800 1080p Home Theater DLP...
How do you rotate the picture
If u have installed the projector to the ceiling, u will see the image upside down. for this u need to orient the projector image upside down
use the remote,
go to menu, installation, front ceiling option, u are done!
Dec 07, 2012 | Panasonic PT-AE8000U Full HD 3D Home...
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
Projector is suspended from the ceiling upside down and so it is projecting upside down. How do i get it to project the images the right way up?
Since you have not mentioned the model it is diffficult if the option of reverse image is available on the menu. If so all you need to do is to scroll the menu and reverse/invert this image. If not the other option is to mount the projector with the projector fitted on a small stand in the same direction and not invereted. I hope you will search for this in the menu or in the rear panel. If not mount it in the actual position with a stand so that you can corrrect the height using the provided screw adjusters.Helpful? Good day
Jul 07, 2010 | Audio Players & Recorders
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
Aug 12, 2008 | Sharp XR-10X Multimedia Projector
Epson PowerLite® 83c LCD Projector Logo
431 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
