I am looking for a crossfire decal that would cover the rear spoiler!
The vehicle is blue. I had seen this on another car a few years ago at a car show. Is this something that is available or needs to be customized?
Hey Ray I'm looking at a picture of this vehicle but I can't see if the lense has screws in it probably not otherwise you wouldn't be asking anyway I think that you will have to remove the rear door trim panel look for little screw covers and pop those out if none then that panel has clips under it and lightly pry up on them from under the panel to release it and I see that it's in the spoiler so there might be a panel to pop out on that trim panel at the top because that spoiler is not part of the rear door it's a bolt in part attached to it from what I can see in the photos and please go to Tasca parts .Com I just found this body/spoiler for 2015 ford edge there's a diagram of the spoiler with fasteners Tasca is a ford dealer in I think Rhode Island but this diagram should help you good luck stephen
Hello! My research finds no reason for a "4" decal to be on the vehicle's trunk...Previous owner may know, in that it held some meaning to them...OR it's covering a mark/defect...Guru.... saailer
NO,but it is normal for the paint to bubble on some plastic trims due to their makeup/type of plastic.the corrosion warranty is not worth the paper you use in the toilet...."applicable only if the paint surface is not broken and rust has taken place under the surface of the paint layers"(how do you know if its rust without breaking the surface to see.........)
I have a crossfire and this has happened to me. When it has I have found that the divider, (for the lack of a better word) that is in the truck is not properly seated. Check to be sure it is all the way into the slot that it fits in, especially on the left side. When it is seated correctly the top will go down. Hope this helps.
Hi mount on a 2005 limited roadster (and maybe coupe?) is the string of brake lights under the spoiler. on other vehicles, it is simply the 3rd brake light.
