Question about Panasonic TC P42S1 42 in. Plasma HDTV
Panasonic TC-P42S1 42" 1080p: there are two wide
  • 158 Answers
To remove the black bars from the left and right hand side, press the FORMAT button on the remote. The options available to remove the vertical bars are H-Fill, Just, and Zoom.
To remove the black bars from the top and bottom, press the FORMAT button on the remote. The option available to remove the horizontal bars is Zoom.
Hope this helps you!!
Posted on Mar 24, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Panasonic Expert
  • 177 Answers
Damage with a vertical straight line derived from plasma or lcd panle.
if you have the equipment and experience in the field of electricity, please open the lid back of the tv. Check and clean the connection between pcb and panels. Usually dirty and corrosion can cause symptoms such as vertical lines.
  • Basuki Jrobenk
    Basuki Jrobenk Mar 25, 2011
    Call technician if still problem with panel line. I hope not panel defect, because it so expensive.
  • Basuki Jrobenk
    if that line still appear, call technician to recheck that problem, i hope not from panel , because its so expensive.
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Light gray screen with vertical color bar in center
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 29, 2015 | Panasonic Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Panasonic TC-P65VT25 has a black vertical line half way down screen.
Sounds like you've had a failure of a part in the electronics. Plasma TVs use pretty high voltages (like the old picture-tube models) and parts can get fried over time. You'll need to have your Panasonic serviced by a qualified technician. Don't try to do it yourself -- high voltages, remember?
Nov 01, 2014 | Panasonic Televison & Video
2" wide bar in center of Panasonic plasma TH-C42FD18 TV
The C5 board is bad. It is replaceable. Warning. always disconnect power cables from power board to y main on left and x main on the rt before ever messing with fat cables on boards across the bottom . The are created if power power is not isolated will vaporize these flat cable destroying the plasm panel. thes boars across the bottom are the c boards. If one of the connectors is loose it will create an vertical black bar in proximity to that connector. If the connector is not loose then replace that board. Also panel could be bad if c board does not fix. But remember to never connect or dissconnect these flat without disconnecting the power board from the sustain boards.
May 31, 2013 | Televison & Video
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
Panasonic TC-P54S1 mounting hole pattern
See page 8 of the manual at: http://service.us.panasonic.com/OPERMANPDF/TCP42S1.PDF The bracket shown there looks like the mounting holes (4?) are vertical on the back of the TV. They may be identified by an arrow pointing to them. There will be two holes on each side of the TV centerline to attach the vertical components of the bracket that hang on the horizontal angle bars on the wall.
Oct 06, 2009 | Panasonic TC-P54S1 54 in. Plasma HDTV
Panasonic TC P42S1 42 in. Plasma HDTV Logo
343 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
