Question about Nikon Cameras
Hi, My Nikon lens is stuck and cant retrieve back. In other words it has malfunctioned...Nothing i can do with it but to stare at it. Cant even view photos neither take some..its so sad
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Nikon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free and prompt answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 24, 2011
I cant see throu my camara dontknow what happend to my lens
It is not the lens. The condition is the aperture will not function as a result of the main circuit board malfunction. Check the polarization of the power supply battery and cell strength.
Apr 16, 2015 | Nikon COOLPIX Cameras
Lens stuck and I cant get the camera turned on. I have a nikon coolpix s4100
Low battery voltage left the lens in a position that the electronic circuit can not resume the next operation. Its a typical Nikon digital camera problem. The tolerance on the lens barrel maybe too tight. The solution maybe replace the lens assembly.
Feb 10, 2012 | Nikon Coolpix 4100 Digital Camera
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change...
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
Mar 06, 2011 | Sigma Telephoto 105mm f/2.8 EX Macro...
My nikon coolpix s210 has a lens error. I turn it on and the lens comes out. It make a err sound and seems like it cant focus. it goes back in and says lens error until i turn it off. I need it. I cant...
if its brand new, then you can replace the lens array for free of service charges in the case you have all the documents. it generally happens if you have dropped the camera.
Jul 09, 2009 | Nikon Coolpix S210 Digital Camera
Aperture cant be changed on manual mode
Maybe a lens problem. Try to re-seat the lens and play with the Aperture test button on the right side of the camera (near your right finger)
NOTE: Please rate our help to keep this free service online
May 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Nikon lens 18--55mm stuck
Dropping is the most common cause or a knock whilst whilst the lens is out.
Dirt ingress is another possibilty.
It is almost always physical damage - or a low battery.
There is- as always this out of warranty items of this class no repair opportunity
Jul 27, 2008 | Nikon COOLPIX L3 Digital Camera
Hi i have f80 camera film and the lense it doesnt work,cose it fall dawn,so how can i fixe it or if u have one to buy it how much the cost for that ?thank you
Your question is in the title so I cant see your whole question. so I hope this helps.
Im going to guess your lens is not Auto Focusing?
Then First I would make sure the switch on th side is set af for auto focus. then I would check the connection. take the lens off and then reconnect it and make sure you feel or hear it click. if that doesnt work try changing the batteries even if the battery meter says they are good. Sometime the battery meter will get stuck.
I hope that was you question.
If not then contact me and I will answer your other question,
caleb
Jun 25, 2008 | Nikon Cameras
Camera Lens up, not turning on
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Apr 19, 2008 | Nikon COOLPIX L4 Digital Camera
Nikon cool pix L11lens error
Remove the battery, wait a couple of minutes, replace battery. (assuming the battery is fully charged. Check there is nothing jammed in the mech. if it still stays stuck.
Dec 30, 2007 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
