Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
I have a Canon powershot SD 1200. I was in Israel traveling, went to the Dead Sea for pics. Was not in sand or the water! But, now it will not turn on. Battery is fully charged. Was not dropped. Any suggestions?
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism (it can only take one or two blown bits of grit or sand getting stuck in the wrong place, and there's plenty of that in Israel), or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 24, 2011
View/Import pics from folders
Just connected the camera at pc and search as external device... or use one external card reader in order to connected your SD Card at pc.
Aug 08, 2012 | Canon PowerShot A480 Digital Camera
Canon powershot s90 wont turn on. used it and took pics and it worked fine. shut it off. went to use it a day later and dead. new batteries didnt help.
If you already tried a second battery with no luck, you'll need to have it serviced. If the camera is over a year, the manufacturers warranty is up. If that's the situation, go to this site www.camerasandparts.com All they deal with are Canon Powershot cameras and they do excellent work, the best part is they are much cheaper than Canon. They do really great work on the Canons. That's were a lot of people go for help with the Powershot models.
Mar 17, 2012 | Canon PowerShot S90 Digital Camera
Any internal backup memory??
The internal memory only works when no card is in the camera and then only holds a small number of pics. If you had the memory card in the camera most of the time, most of your pics were on the card.
Jul 07, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon powershot sd 1200 wont turn on i have recharged the battery. what else can i try?
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Jun 01, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My canon powershot sd950 is not turning on after I finished a travel by plane. The battery is brand new and when I shake the camera there is no noise.
I had the same problem. I sent it to Canon and it came back today fixed and free of charge even though I've had it for almost two years. Then I tried using it again tonight and it doesn't work again. I charged the battery pack, still not working. I found out that this camera has a service notice for it on canon's site. My camera does have one of the serial #'s they describe. I guess they fixed it for free b/c it was a loose screw but now it's come loose again the same day. How frustrating! I have to have a camera for tomorrow so I'll go buy another camera. I'll still send this one back to Canon and see what they do this time.
Here's the link so you can check your serial #. Good luck!
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=224&modelid=15652&keycode=2112&id=55260
Oct 30, 2009 | Canon PowerShot SD950 IS Digital Camera
Change old pics from black & white to color on a canon powershot
You have it on a filter setting that extracts color...go into the menu and scroll to filters and change the setting.
Oct 22, 2009 | Canon PowerShot SD870 IS Digital Camera
Can't download pics from sd to camera
Goto any radio shack and get a external memory card reader this will allow you to get your pictures if the camera or cable is defective.
May 22, 2009 | Canon PowerShot SD850 IS Digital Camera
Pwereshot A95 suddenly quit!!
This is Manufacturing defect.Canon will repair it free of cost.I had same problem and canon had repaired mine after warrnty period free.
Jul 06, 2008 | Canon PowerShot A95 Digital Camera
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
