Question about MSI MSM LGA1156Intel H55uATX 6x SATAII1xPCIEx161xP H55ME23 Motherboard
My motherboard won't bootup after I installed it in the case
    Master:
  • 344 Answers
Make sure your screws are all in the anchor points. Also make sure you have the proper power supply for the motherboard. That all the power connectors are plugged in correctly. Also double check any and all connections to the motherboard. Especially the connector that your main power switch plugs into. My motherboard won't bootup after I installed it - adracamas.jpgOf course at this angle I couldn't tell you where it is... but it seems to be polarity dependent.
Posted on Mar 24, 2011
Had a power failure in my area, my dell desktop was on at time. When I turned it back on I got blue screen which I know is not good. Decided to install new/bigger harddrive since I need to install windows...
Hi, you need to change your primary boot device, try pressing the F1 key during bootup, this will take you to the BIOS screen, from here you can change your primary boot device from HD to CD, save your changes, reboot, selecting boot from CD when it appears during bootup.
Hope this helps
Jul 21, 2010 | Dell (E210882) Motherboard
It won;t bootup
Is your monitor plugged in and turned on? There may also be a bad connection between your computer and monitor. Failing that, your motherboard may be bad.
Jul 10, 2010 | Compaq Presario 5000 PC Desktop
Trying to boot fm CD/RW drive. Can't get at CMOS/BIOS to change boot process. Motherboard is Intel D875PBZLK -875p. F12 at bootup doesn't bring it up, nor does, F2, escape, delete. Using Windows XP SP3.
The command key is F2 - start pressing it immediately after you pressed the case start button and don't release it until the bios is loaded. If it doesn't work then probably your keyboard is iffy, try with another one.
Oct 24, 2009 | Intel D875PBZLK (D875PBZLKPRESCOTT)...
System can't bootup any cd or dvd
Do you have a Win98 install CD? If yes, you should be able to tell it to boot with CD-ROM support.....then use xp disk to load or install your OS.......I'm doing that right now on a different system. It will format your drive first....which takes a looooooooooooong time, however, it is worth it.
Sep 27, 2009 | Intel Motherboard
Boot disk error insert system disk and and press enter.
it is a hard disk error. most likely your hard disk is defective since is it not registering well. please try to use 80-pin interface cable to correct the problem or change your Hard Disk
Sep 21, 2009 | ASUS P4S533-MX Motherboard
SOYO's SY-P4VTP with 3GHz Pentium 4 Processor does not bootup.
check the rams and if they are ok
try to reset the bios settings from the motherboard jumper settings. like clear CMOS jumper will be there.
Apr 17, 2009 | Soyo (SY-P4VTP) Motherboard
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Bios error
It could be a low CMOS battery. Please replace it and let me know.
Oct 19, 2007 | ASUS P4P800 SE (890552603657) Motherboard
NO response
can you post a little more info, as the case you fitted the motherboard to, does it have a new power supply, as it could be the power supply unit, if it came with a psu then check the cmaos battery and as long as you know you have connected the front panel connectors correctly, if theres no sign of the drives flashing it may well be the processor, but more info please
Jun 14, 2007 | EliteGroup P4VMM2 Motherboard
MSI MSM LGA1156Intel H55uATX 6x SATAII1xPCIEx161xP H55ME23 Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
