Question about Frigidaire FMV156DC Microwave Oven
Light bulb change
I have a frigidaire micro and need to change the interior bulb. Any suggestions as it does not show in the manual?
Thanks.
  • Frigidaire Master
  • 9,011 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Frigidaire owner's manual and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 03, 2008
Carousal II Micro/Convec. Model R-9H84
It is there! Go to appliancepartspros.com and check out the plans for the location of all parts. Then get to it.
Sep 06, 2015 | Sharp Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
How do you replace the light bulb on the built in model Frigidaire FMB136G1B
That model number is not showing up for me to find the owner's manual online.
If your owner's manual does not cover it, then you'll have to remove the oven from the wall, then remove its outer wrapper.
Otherwise, I'd suggest you contact Frigidaire Customer Service at http://www.frigidaire.com/contactus
Nov 29, 2009 | Frigidaire Microwave Ovens
How do you change interior 20 w lamp?
remove the 3 screws on the vent above the door. Next unplug the oven from the power source.Next you will see a single silver screw above the control panel..remove it and slide the control panel upward and out. This will give you access to the lamp socket...turn it left or right and pull slightly ...you can now unscrew and replace the bulb....It was my exp that the lamp got loose in the socket from slamming the door after about a year, and I only had to tighten the bulb..Hope this solves the problem...Jerry
Mar 19, 2009 | Frigidaire FMV156EM Microwave Oven
Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
Feb 07, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Oct 19, 2008 | GE JVM1790 1000 Watts Convection /...
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
There may be a panel on the bottom covering the light(s), too.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Replacing interior light bulb in m/n 63694
On many recent models, it is necessary to remove the mircowave from the wall, then remove the cover to change the cavity bulb. They suggest that only an authoirzed servider replace them, in order to avoid liability. You can enter your actual, full model number (63694 is not enough) and get helpful exploded view drawings and order parts at http://www3.sears.com (the three is correct). Do not handle the bulbs with bare skin, it will shorten their lives. Use a clean dry cloth or gloves.
Apr 29, 2007 | Kenmore 63692 / 63694 / 63699 900 Watts...
Frigidaire FMV156DC Microwave Oven Logo
176 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
