Question about Sony Audio Players & Recorders
Having a problem setting up my mp3 player. I have it installed in the usb port and have managed to get to the storage media file, but now i am unable to get to install wizard so i can install. help.
  • Bryan Daugherty
    Bryan Daugherty Mar 24, 2011
    What is the make and model?
    Master:
  • 344 Answers
Check out http://esupport.sony.com/perl/select-system.pl
There you should be able to download the latest software for you device.
Posted on Mar 24, 2011
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
STEP 2 - Check under Device Manager
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
STEP 3 - Refresh the drivers
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Not connet on computer
Hi, Sony NWZB133F MP3 Player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sony NWZB133F MP3 Player not recognized by a MAC OS
STEP 1 - Connect the Sony NWZB133F MP3 Player to the PC
NOTE: Sony NWZB133F MP3 Player can connect to your computer in MSC or MTP mode. Exceptions are Sony NWZB133F MP3 Player Connect and Sony NWZB133F MP3 Player Express which only use MTP mode. MTP mode is the recommended and default method for Sony NWZB133F MP3 Player when used with Windows OS.
The Sony NWZB133F MP3 Player will show up on Device Manager's right pane as:
Have a nice day....
Feb 22, 2011 | Sony NWZB133F MP3 Player
I connect my device(philips gogear Vibe 4g.)The device shows as "connected device"on "Media Converter for Philips" program , and when converting VIDEO files is "done" , report screen shows "NO DEVICE...
Hello :
1: Unplug your Mp3 player . 2: Restart system .
3: Plug the Mp3 player again . If the system didn't recognize Mp3 player this time , then :
1: Go to [ my computer ] icon on desktop .
2 : Mouse right click .
3 : Scroll down to properties .
4 : On properties click [ Hardware] .
5 : Click [ device manager ] .
6 : On device manager check if all [ USB ports ] are properly installed and working fine .
7: If there are [ question marks or wrong marks ] on the ports then they don't work properly .
This is what you need to do , if they don't work properly ;
1 : Right click on the none working ports .
2 : Scroll down to properties .
3 : On general click [ reinstall the previous program ] .
8f47b2d.png My computer icon .
Device manager
USB mass storage device problem [ not working properly ] . Here you should right click on the none working device then go to properties and then ,
f4d6255.jpg\
Troubleshoot .
I hope this will help .
rate please !
Mar 27, 2010 | Philips GoGear Flash MP3 Player
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
I am trying to put more songs onto my mp3 player. The songs show that they're on there on the computer, but when i unplug it the songs aren't shown on there. It says i have plenty of space, so that's not...
Hello.
Welcome To Fixya.
In order to have a succesful Transfer of songs from you computer to your mp3 player follow these Steps:
1/ Install:
  1. Insert the CD supplied with your product into the CD ROM drive of your PC.
  2. Follow the on-screen instructions to complete the installation of Philips Device Manager and Philips Media Converter. The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player.
2/ Connect and charge:
  1. Connect to PC:
    When you connect the player to the PC, it automatically charges.
  2. Connect the supplied USB cable to the mini USB port at the bottom of the player, the other end to your PC.
3/ Transfer:
Your player appears as a USB mass storage in Windows Explorer. You can organize files, transfer music and picture to your player during USB connection. Use Philips Media Converter to transfer video file. See Media Converter for details.
Transfer music:
  1. Click and highlight one or more songs to transfer between your player and your computer.
  2. Use drag and drop actions to complete your transfer.
Tip : To transfer music CDs to the player use software such as Musicmatch Jukebox or Windows Media Player, rip (convert) the songs on your music CD into MP3/WMA files. Copy the files into the digital audio player via Windows Explorer. Free versions of these programs can be downloaded from the internet.
Also you can Transfer Video:
The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player. You can install the software from the supplied CD.
Thank You For Using Fixya.
Good Luck.
Nov 06, 2009 | Philips SA3025/37 Flash MP3 Player
Sony Walkman NWZ-S736F MP3 wont connect it charges but dosent show up on the content transfer
Uninstall problem MTP device in device manager. Reinstall it as a USB mass storage device. It should connect to the USB port. Unintall that USB mass storage device. Scan for hardware changes. It will find your mp3 player and install it. In the window to choose what action to take, choose sync music. Media player will open and connect. So then, will your other apps.
Jul 11, 2009 | Sony Electronics - Others
Connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Nov 15, 2007 | Panasonic SV-MP020 MP3 Player
Transfering music using windows 2000
You need to have Windows Media Player version 10 or higher to transfer files to an MP3 device.
You can drag and drop files manually from My Computer as well.
Best of Luck.
Nov 07, 2007 | Audio Players & Recorders
14 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
