Hello, The laptop does not connect to wi-fi. I rebooted it to factory settings, no results. Perhaps, I did not activate any wi-fi switch? I noticed that F8 has a character WiFi picture on it yet it has to go with some combination. Please advise. Thank you. Andrew
  • 3,289 Answers
Hi Andrew,
As you have guessed, the wireless radio in your notebook will have to be on before you can connect. The F8 key you mentioned with the wifi symbol will likely be the switch to enable and disable it. Usually, the key board has a separate "F" or "Fn" (Function) key that would be pressed and held - and the tap the the "F8" key to toggle the wifi radio on or off. If you did not hold the F or Fn key I'm talking about - it would have nothing to do with the wifi radio. It is imperative to find the F or Fn key on your keyboard to make this work.
A message indicating the status of the wifi radio being on or off show flash on the screen or light up an led on the the notebook somewhere. Once you believe the wifi is on, connect to the wireless router when you are shown a message about wifi networks in range on the screen. If there is more than one network, you'll be provided a list from which to choose. If the SSID of your router is being broadcast, you should see it in the list. Select your own wifi network. Provide the security credentials to authenticate (if asked). This would be the security key. This key should be the same key that is in the router's wireless security page. If your router is not broadcasting the SSID of the network, your notebook will not detect the network. You will have to manually configure the notebook to connect to a specific network by identifying it first. If you do not know the security key or the SSID you will have to check the router's wireless security setup page to see it or change the key. You should also see the name of the network on one of the wireless pages in the SSID box. You can view or change the name here if you wish and you can enable or disable broadcasting the SSID as well. Lastly, you'll have to supply the security credentials, etc. when setting up the network on the notebook If given the opportunity to "always connect to this network when in range" be sure to select it so the next time you want to use the notebook's wifi connection here - it will automatically connect for you.
These are fairly generic instructions as I don't know which notebook, wifi card, or router you have. You should get an idea as to how this works from this however. I hope this was helpful and good luck! Please rate my reply. Thank you.
Posted on Mar 24, 2011
Testimonial: "Thank you very much!"
How do I launch apps on my phone using mobile data instead of WI-FI.
go into setting and look for connection settings or internet setting and then look for an option of using data or data packets olong those lines and select the option for mobile data and de-select the option of connecting with wi-fi
Nov 27, 2014 | Cell Phones
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Wlan card disabled
The Dell Latitude E6400 laptop comes with an Intel Core 2 Duo processor for fast computing and an NVIDIA graphics card for video playback, gaming and Web browsing. The laptop has a built in Wi-Fi card, letting you connect to the Internet on-the-go. However, if you're unfamiliar with Dell or the laptop's factory installed Windows Vista operating system, you might not know how to enable to Wi-Fi.
Slide the switch on the side of the laptop toward the front of the laptop. This switch enables Wi-Fi connectivity on the Dell Latitude E6400. When switched into the back position, the Wi-Fi is turned off. Turn on your Dell Latitude E6400 laptop and log into Windows Vista. Click on the Windows "Start" button. Click on "Wireless," located in the Start menu's "Show" list. A list of currently broadcasting wireless networks appears on screen. With your Wi-Fi enabled, you can connect to any of these available networks. Secured networks ask you for a password when you click "Connect," while unsecured networks connect automatically.
Feb 03, 2013 | Dell Latitude E6400 Notebook
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
The problem with my laptop is that I rebooted the computer and everything went back to factory settings, I cannot link up with internet using wi-fi capabilities, I press the wi-fi button on the right of...
What do you mean went back to factory settings? Are you referring to the bios settings? Or other else? If you are referring to the bios settings, and everytime you change the bios and rebooted, then back to factory settings then your problem maybe the cmos battery. You can change it and try if everything works fine. And maybe you can't connect using wifi because it is disabled in the bios settings or if not you got a defective wireless module. Hope this will help pal. Maybe you should elaborate your situation more detailed as what is really happening to your laptop,
Aug 29, 2010 | Acer Aspire 5735 Notebook
Wi-fi connection..?
In my acer laptop, there's a switch on the front to activate Wifi capability.
Jul 21, 2010 | Acer Computers & Internet
Wi fi on ACER Aspire 4810T connects intermittently
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
Nov 17, 2009 | Acer TravelMate 4062WLMi Notebook
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
