Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
Can't connect to the internet using Vista OS on Compaq laptop. Using a WNDR3400-100NAS Netgear router. It finds the router and it labels it as an unidentified network and it will not complete the connection to the internet.
    Master:
  • 344 Answers
I am assuming you HAVE connected before.
Here is how to fix that corrupted DNS cache in vista.
1. Click the Microsoft Vista Start logo in the bottom left corner of the screen
2. Click All Programs
3. Click Accessories
4. RIGHT-click on Command Prompt
5. Select Run As Administrator
6. In the command window type the following and then hit enter: ipconfig /flushdns
7. You will see the following confirmation:
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
After that in the same command window type
ipconfig /release
ipconfig /renew
That should clear up the issue. Odds are you were sharing an IP address with someone else on the network.
Posted on Mar 24, 2011
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
Jan 18, 2013 | NetGear MBRN3000 3G /4G Mobile Broadband...
What's the most current OS I can use to replace Windows 98 on a Compaq Presario 1277 laptop?
You might be able to find a stripped down version of XP or put Windows NT on it. Those are my best guesses. NT will let you use newer versions of some browsers as well. Mostly Explorer
Dec 11, 2012 | HP (158800-001) for Compaq Presario 1246,...
I DONT KNOW HOW TO PUT MY NETGEAR ROUTER THROUGH MY LAPTOP , SO I CAN HAVE WIRELESS INTERNET ACCESS
u will need RJ45 CABLE (normal ethernet cable, labelled cat5e)
plug one end into laptop network connection other into laptop
login address will be (netgear) details will be under router
http://192.168.1.1pi
or something like that.
login id: admin
password: password
if u cant login then, press reset button back of wireless router, will need to do that with pen or pin?
once logged into the router, use the setup wizard and the the rest is self explanatory.
once setup is dne, with SSID and password, then plug the cable from laptop, in back of the internet modem coming into ur house from ur supplier....and ur ready to surf the web.
find your new wireless network using the laptop and insert the password....
Oct 10, 2010 | NetGear WGR614 Wireless Router
Netgear will not connect to the internet on my laptop
Check the power adapter to the Netgear router with a multi-meter. The voltage should be slightly higher than the voltage that is printed on the label on the power adapter.
Feb 11, 2010 | Gateway 450ROG Notebook
Can't connect to netgear wnr 2000
conect to netgear then shut down and turn it back on.
May 27, 2009 | Acer TravelMate 5520 Notebook
Can connect with usb stick on one PC and through inbuilt wireless on a laptop to the main router but not a new one
becos of you using three different os one is xp,other one is vista and other on is xpsp3 all the driver is different so how can he connect it.
Sep 06, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Wireless connection of netgear wireless router for compaq laptop
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
663 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
