Question about Samsung HLR5067WX 50" Rear Projection HDTV
Wear is the color wheel located - Samsung HLR5067WX 50" Rear Projection HDTV
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
color wheel locatied on assy angine. wear is the color wheel - mas_baz_25.jpg
than open it.
Good luck.
Posted on Mar 24, 2011
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
I have a optoma rd65 when on it makes a loud humming noise
You most likely have a failing color wheel. This is a known problem in the RD65. If you search on EBay for an RD50 color wheel it is the same one that goes in the RD65. They are roughly $150 depending on who you purchase from. They can be user replaced if you are handy with tools. The bearings wear out and this causes the humming you are hearing. Optoma RD50 color wheel replacement AVS Home Theater Discussions And...
Sep 23, 2014 | Optoma RD65 65" Rear Projection HDTV
Color wheel flashes multiple colors after operating fine for about 7 minutes. Shuts down on it's own and temp/power light blink amber. No heat exhausting from fan. Problem persists.
hi,
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
ok
Jul 27, 2011 | Dell 1409X DLP Projector
Where is the color wheel located on the dv10 projector
The color wheel using in DLP projectors only and located inside projector just after the lamp. If you have LCD projector than there is no any color wheel.good_help_2.jpggood_help_3.jpg
Jan 14, 2011 | Office Equipment & Supplies
Is the color wheel fine if it is spinning? Can you see any light from the dlp lamp when the screen is off? I had a service guy come by to fix my dlp and he replaced the bulb with no luck. He said it was...
First You can look on the rear of the set and see the lamp light shine through the lamp door vents when the set is on. Second you need to replace the whole color wheel before the set will work. Third Color wheels may spin but not at the correct rpm and may shut down the tv and sometimes color wheels will emit a high pitched whine or buzzing sound indicating that the bearings in the motor are wearing out. But now that you have to replace the color wheel you will need to adjust the index delay in the service menu. I suggest having a factory trained tech repair the set.
Jul 10, 2009 | Televison & Video
COLOR WHEEL REBUILD
I did it. With proper lubricants, that contain solid particles applied to the bearing, may overcome the wear-out on the bearing and get back the clearance in the range.
The RCA color wheel in question had similar problem and after the procedure it is working like brand new.
Dec 19, 2008 | Televison & Video
60" Samsung HDTV
Thats a very good possibility. The bearings in the color wheel eventually wear out. Have you noticed any noises lately when the green is messing up.?
Jan 19, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-R5667W
Color Wheel problem.. to generate colors on a dlp the light is shine through a motorized wheel. that has different color filters on it. this is a motor and anthing that moves will eventally wear out. i just replaced the color wheel on a samsung today. standard for this to go out in about that time. i believed our shop charged 250 to put a new one in. Willie@FORDTV.COM
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
