Question about Dryers
Simpson dryer 39p400 belt install - Dryers
5 Suggested Answers
  • 686 Answers
SOURCE: Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Posted on Mar 12, 2009
dragonsthatk
  • 547 Answers
SOURCE: changing a belt on a simpson dryer
on what ever side ot the belt it cause's more tention thank you for useing fixya rate me
Posted on Mar 31, 2009
SOURCE: Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Posted on Jun 29, 2010
heatman101
  • 43501 Answers
SOURCE: i have a simpson 39P400
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 23, 2011
Small condencer on my 39P400 has two coloured wires red &blue which wire goes onto what pole ??
Either way around it doesn't matter. Unless it is marked with a P & N or + & - then red would go to P or +
Jun 15, 2017 | Simpson Washing Machines
How do i change the drum belt on simpson minimax dryer
You will have to disassemble the dryer sufficiently to gain access to the belt, then remove it, install a replacement belt, and reasssemble the dryer.
Mar 02, 2015 | Dryers
I have a simpson 39p400
The start switch itself apparently has broken internally. Try replacing the switch.
May 21, 2012 | Dryers
I have a simpson 39P400 dryer. the drum turns as it should but it only blows cold air. have had the heater element block checked and ok. is ther a cut out relay or ?? that i can replace.
heatman101
May 23, 2011 | Dryers
Jun 21, 2010 | Dryers
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Changing a belt on a simpson dryer
Mar 31, 2009 | Dryers
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
306 people viewed this question
Top Dryers Experts
