Question about GE Microwave Ovens
We have a WES1450 GE Microwave at work. Purchased in December 2010. It stopped working this morning. Now the LED display says Power Level Can Not Be Changed At This Time. We checked the plugs everything is as it should be. Is there something we can do or do we need to return it?
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Model MH3184XP will not power up after power failure
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again. Let us know if the hard reset doesn't fix it.
If not, then you may have a problem is on the control panel, which we repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: can't adjust power level
You can download GE owner's manuals and installation instructions here.
Let us know if you still need help after reviewing the manual.
Posted on Sep 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You should be able to get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Posted on Jun 08, 2009
SOURCE: Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Posted on Jan 31, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: How can I change the power level on my GE Spacemaker microwave?
You can download your owner's manual here.
Posted on May 16, 2010
Ge wes1450
You have to remove the outer enclosure to gain access to the lamp. read and heed the warnings about high voltages before poking around inside.
Mar 01, 2014 | Microwave Ovens
GE Spacemaker microwave oven seems to have no power
look for white small fuse inside by power cord are on small board
Jan 04, 2014 | GE SpaceMaker Microwave Ovens
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 14, 2017 | GE Microwave Ovens
Is there a way to correct a keypad short on a wes1450 GE
No, sadly the WES series ovens were made for the rock bottom market, and GE does not make any parts available for them except the turntable and turntable support.
If it's under warranty, you can return it to Walmart.
If not, it's off to the dump.
Sorry to bear bad news.
May 22, 2011 | GE Microwave Ovens
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
Jun 04, 2008 | Kenmore 63663 Microwave Oven
Microwave Ovens Logo
357 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
