Question about Vacuums
When you remove hose and insert the attachment for cleaning stairs there is no suction
    Sergeant:
  • 259 Answers
There is something lodged in the attachment clogging it up.
Posted on Mar 24, 2011
BRUSH WON'T TURN ON THE STAIR ATTACHMENT
something might be stuck on it or it is broken or try to move the brushes
Jan 10, 2017 | Vacuums
How to attached stair cleaning attachment
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How to I attach the stair / couch hose cleaning tool
on the rear of this model there is a suction port that you can open to attach the hose and tools
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 20, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do I attach the stair cleaner attachment
  1. remove recovery tank lid
  2. remove tank duct from front of tank
  3. slide flat end of hose into slot where tank duct was<open side up>
  4. place tank lid back on
  5. open water hose door on hood
  6. push waterline onto spickett
  7. clean your stairs.
best of luck
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Using stair attachment, ++water leaks onto floor under the unit;
clean solution will flow to the tool properly. Follow
these steps:
1. Attach tool to hose and turn the deep
cleaner ON.
and begin cleaning.
Feb 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction with attatchments
if you have cleaned all the filters, there are two you need to wash and the hepa on the back may need to be changed, but the hose is probablly clogged. You can usually remove the hose ( twist it where the hose connects to the machine ) and use a broom stick to try and push the clog out.
Jan 12, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction in carpet cleaning mode with Empower
Check the nozzle . Turn it over on it's belly and remove the 4 screws that hold the base plate on. Take off the plate and remove the brushroll. I bet you will see a clog in the intake. If not take it to your local vac shop and let them fix it.
May 28, 2017 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Stair attachment has weak suction
Did you put the duct in for the hose? It goes in front of the tank, take out the duct (#3)that is there and put in the duct that is on the end of the hose. Is there a slit somewhere in the hose, if so you will loose suction.
Nov 17, 2007 | Hoover F5826-900 SteamVac Upright Wet...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
