Question about Trixter X-Bike 1000 Indoor Cycle Exercise Bike Bicycle
Ok. The Trixter 1000 apparently has 32 levels of resistance for pedalling, yet there are only 9 settings on the right handlebar to alter resistance. Is there something I'm missing here?
  • palomab Mar 27, 2011
    Excellent! That's just the info. that I needed, thanks :-)
    President:
  • 1,140 Answers
Hello there,
You are missing the second resistance adjustment. There are 9 positions on the grip shift, but one offers no resistance so there are 8 resistance settings here. In addition there are four positions on the second adjustment. 4 * 8 = 32.
The secondary adjustment is made by turning the small black adjustment wheel where the cable exits the grip-shift.
This adjustment isn't highly significant. Technically, I suppose they can claim 32 resistance levels, but in reality it will probably feel more like 16. If you want extra resistance, you could also tighten the cable on the v-brake, but this is liable to stretch the cable and wear the brake pads out quicker.
Hope this helps.
Regards,
BElectric
Posted on Mar 24, 2011
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
The resistance won’t alter after moving bike and removing the handlebars. It is a DKN 2100i .
It is not apparent from looking at pics of the machine what the trouble is, nor is there a troublehooting guide in the manual. Most likely you disconnected or damaged some wiring going from the control console to the wheel where the resistance is typically managed. I would suggest you contact the manufacturer and see if they can give you any guidance or perhaps direct you to a local resource, like an authorized repair facility or a gym that uses their equipment.
Dec 10, 2017 | Cycling
Need pedals for resistant exercise bike with movable handlebars
ive found that bike stores (even online ones) have pedals for decathalon bikes that have the foot straps these should ***** right on to your stationary bike just the same , I will say there a bit pricey !!!
Apr 13, 2016 | Exercise & Fitness
Schwinn 220 recumbent bike alternates between pedeling fine to barely being barely able to move every 20-30 seconds no matter what setting. There is also a squeak/noise while the unit is plugged in,
make this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
    • 2
Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
    • 3
Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
    • 4
Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Dec 05, 2013 | Schwinn 220 Recumbent Bike
Golds gym 380 elliptical is not increasing resistance
follow this steps, God bless you
    • Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
    • Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
Nov 14, 2012 | Golds Gym StrideTrainer 380 Elliptical
Why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Dec 06, 2011 | Exercise & Fitness
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Jan 04, 2010 | Exercise & Fitness
Trixter X-Bike 1000 Indoor Cycle Exercise Bike Bicycle Logo
91 people viewed this question
Top Trixter Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Trixter Cycling Expert? Answer questions, earn points and help others
