I have purchased local transformer (12v 5amp) but real adapter voltage is (13.5v 6000amp) & sound is not OK so what to do now
    Master:
  • 344 Answers
You will just have to try and take it back. You don't have enough voltage and/or amperage to cover the devices needs.
Posted on Mar 24, 2011
Need the amp rating for the 12v power adapter on Boston BA635 speakers/subwoofer
The bigger the better. It will either get hot if it's not powerful enough, or work ok. The amperage isn't important. The voltage and polarity are. Worst case scenario is you will burn out the adapter if amperage is too low.
Feb 02, 2015 | Audio Players & Recorders
Sir, I got Epson stylus 480 printer and unfortunately in Pakistan voltage is 220v but i imported it from america where voltage is 120v so i directly turned it on and it started once on 220v and now not...
What you should have done before using your Epson stylus printer was to purchase a Voltage Converter able to convert 220 volt into 120 volt.
You probably "burned" out the printers electrical circuit because you let 220 volt directly into a device built for 120 volt.
If it is the other way around f.ex. connecting a 220 volt device into a 120 volt outlet it will not destroy the product. Only the product may not work as it is supposed to or it will be slower.
Here is a site with a voltage comparision chart, that can help you to choose a Voltage Converter for your purposes.
http://www.110220volts.com/Power/Voltage+Converters.html
Regards
Sep 15, 2011 | Office Equipment & Supplies
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
I have a maxtor 120GB external hard drive but no power supply. How do I get a replacement? I tried a switchable power adapter from a local hardware shop and although I set the voltage to 12v it lights up...
Hi Dave.
The problem you are having is the adaptor you tried is the right voltage but not the correct ampage. You require a 12v dc adapter with a rating of at least 1-Amp. The switchable supply you purchased would be well under the required level, probably 400ma (milli-amp), in other words about half the needed amount. A cable modem power adapter would be sufficiant. If you have one, make sure it is the correct voltage and polarity, positive pole (+) usually the inner pin on the end of the connector. Hope this is of some help to you.
Jan 25, 2011 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
I have a TVDVD092 and have misplaced the cigar lighter adapter. I know I need a 12v adapter. How many amps does this device require? Thanks
Hi
A 5amp fuse should be ok in the 12v adapter if you are bying a new lead make certain you by the correct one as some leads have the center pin + and some have center pin - look on the set by the power input plug to find out the one you require, regards windyhouse
May 17, 2010 | Orion TVDVD092 9 in. TV/DVD Combo
Amp MC-D80. No Indication of power on.Checked power supply board(no schematic). No + or - 12v. All other voltages seem ok. Any known common failure? Thanks Art
Simply follow the 12v supply back to where it starts, which should be where the transformer wires join the PC Board. If you don't have 12v AC there the transformer has gone. If you do, then follow it with your multimeter till it goes. That will lead you to the culprit.
Jan 07, 2010 | Audio Players & Recorders
Hi ,my ps3 power pack has stopped working.I have mains voltage in and the board mounted fuse is good .I dont have the 12v from the pin contacts or 5v & 12v on/off from the white flying connector . any...
Check the voltages at the input terminals & output terminals of the transformer. If you find voltages at the inputs & no voltages at the outputs, then you have a defective transformer that needs to be replaced.
If the transformer is OK, then start testing the components next to the transformer. There might be a disconnected joint along the circuit path causing the missing volts. You might suspect a failed bridge rectifier section.
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
I can't locate my power adapter for my WD storage devivce
they all use 12V , so just get any 12v transformer that fits
the amp is i think 3.1amp or near.
Mar 04, 2009 | Western Digital My Book Essential 500GB...
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Need charger
What needs to be done here is goto the local Rat Shack, and purchase a universal power adapter for your specific voltage and amperage. Remember to bring your device into the place to match up the tip with the power socket on the device. Tell them you need 1500 milliamps and tell them you need 9 or 12 volts.
The cost should be no more than fifteen dollars total for adapter and tip, usually the tip comes with the purchase of the transformer, and dont purchase one with a variable voltage, just a fixed voltage if possible you can use 9 or 12 volts but it has to be 1500ma(which is 1.5 amps).
May 15, 2008 | Televison & Video
19 people viewed this question
 Grubhead
Grubhead
