Question about Sunbeam 6278 4-Slice Toaster
Toaster will not go down and will not turn toasting heat on
  • 519 Answers
This problem indicates that there is no power to the toaster.
Firstly check the power cord at the plug-open up the plug if necessary & make sure all wires are properly connected.
Next check the cable where it enters the toaster. This is where there is most wear & tear on power cables. You may also have to open up the toaster to get to the power cable connections.
If you have a continuity tester test the entire length of the cable for breaks by testing each core of the cable, namely earth, live and neutral.
Lastly check all fuses, if any.
If the cable or fuses aren't at fault, there is a bad connection somewhere within the toaster & will need to be checked by somebody with experience in home appliances.
Best wishes,
Graemevm
Posted on Mar 24, 2011
Fix sunbeam 3806 toaster that won't stay down and therefore heat bread.
Just a guess since I have had the same happen to my Proctor Sillex - When you push down the lever, you are actually completing the transformer frame that then magnetically keeps the toast down until it's setting lets the toaster pop up.
In my case, a piece of toast was wedged and I could not get the handle down so that the hardware was in place to magnetically hold. Have you tried to give your toaster a good thorough shaking upside down, unplugged over the garbage can or the sink?
Good luck Eric
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
My toaster will not turn off. I press the toast button, it does it's job and then pops up, but the heating elements will continue to stay on.
It sounds like the temperature sensor has malfunctioned. When the sensor reaches a certain temperature it opens the contact to the heating elements shutting off the toaster. If the unit is under warranty then take it to a repair facility for Krups. I would not allow anyone to use the toaster. If left on it could cause a fire. Take care, stay safe and good luck with your unit!
Nov 10, 2009 | Krups FEC212 Toast Supreme 2-Slice Toaster
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Sunbeam 6278 4-Slice Toaster Logo
170 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
