I,have a kennmore Elite model # 11047789701 I,keep getting a f35 code coming on the screen and als suds
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 26, 2010
SOURCE: My Kenmore Elite HE5t washer flashes SUD
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Posted on Jul 04, 2010
  • 1382 Answers
SOURCE: error code F35 and SUD
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Posted on Jul 12, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
SOURCE: Whirlpool duet wfw9600ta01 with the common
WARNING: THIS WRITE-UP IS COMPLETELY MY OPINION BASED ON MY EXPERIMENTATION WITH THE EQUIPMENT. TRY ANY OF IT AT YOUR OWN RISK. YOU WILL BE SOLELY RESPONSIBLE FOR ALL THE CONSEQUENCES (GOOD OR BAD EITHER WAY) THAT YOU MAY REAP FROM THE MACHINE YOU WORK ON.
I made the biggest mistake of taking the whirpool WFW9600TA01 from US to India - I had been totally frustrated with the SUDS/F35 issue, absolutely as explained in the question above.
I started as a novice but feel very confident to write this solution now. There are several areas that could cause this problem. Fundamentally, as the water fills the tub, the pressure form the pressure switch is sensed. If the value is not in line with what is programmed, you get this error. This deviation in pressure value can be caused by any of the below reasons.
First and foremost thing I would do is remove (disassemble - note very carefully the assembly and the position before disassembling. You will need to reassemble in the exact same way in the exact same position) and clean all the pipes, hoses and connectors
Details:
The problem could occur because of:
1. True suds formation due to wrong soap usage (pretty often the problem) - Solution for this? - use a lot of vinegar and a few "risnse and spin" cycles with out any clothes in the washer
2. The pressure switch could have gone bad. Solution - replace the pressure switch (I would do this the last though)
3. There could be dirt collected at the water inlet. Solution remove the water inlet and clean the cup shaped strainer
4. Your outlet/drain pump (the one that pumps the water out of the washer into the drain) may have worn out, there by not draining out all the water. This will leave residual water impacting the next run. Solution replace the pump assembly
5. There may be particle collection such as coins pens, small pins etc in the darn pump inlet strainer causing the drain pump to not work properly and in turn causing SUDS/F35. Solution - remove the front of the drain pump inlet and remove the particles and restart.
6. There is a conical shaped connector connecting the outlet of the tub to the inlet of the drain pump. At one side of this connector (the broader side connecting to the tub) there is a plastic ball in it. If the ball is punctured, water may have collected in it causing it to weigh more than what it is supposed to. When the drain pump runs, the weight of this ball may counter act to not allow proper draining of the water. This residual accumulation of the water will cause SUDS/F35 in the next cycle. Solution - replace that flexible connector. Atleast drain the water from the front at the drain pump inlet, if you want the washer to work for that cycle.
7. There is a small white plastic tube at the back which runs a black tube to the pressure swtich. The assembly is pretty interesting. It is a simple insertion with the air tightness being achieved by a simple rubber gasket covering the insertable part (do not know why the design is such). After a few washes due to the vibration generated by the tub during wash, this gasket can move causing air leaks. Such air leaks do not cause any issue to the current run, but will result in a SUDS/F35 in the next run. It will remain so for al the next runs unless it is re-inserted properly. Solution for this? every time open the rear and make sure the plastic white part is pushed in well.
8. There are other reasons like the main control circulatory / mother board could have gone bad etc. You can figure if this is the problem by running the diagnostic tests for the most part - there is a good chance that only a certified technician can tell you. Solution - replace the mother board (quite stupid huh!!)
9. Finally, the steamer assembly could have gone bad - Although the manual says this, I cannot quite figure out how this would affect the pressure buildup in the tub - I do not know what to do. More than likely if you invite a technician, the person might ask you to replace this assembly.
Try everything - the net effect should be that you have plugged all air leaks. I know some expect to see water leaks at place where air leak exists. That may not be true at all. Good luck with everything.
Posted on Sep 29, 2010
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite front load washer model 46752701. Got the SUD F35 code and changed the pressure switch. I was able to wash 5 loads before the codes appeared again. Changed the switch again but I...
there is a clean out to the left or the pump.it should be in the middle front when you remove the bottom panel.[hint] have a shop vac on with the hose next to the clean out so you don't get water every where.if you do not have a wet/dry vac and it is on a pedistal open the drawer and put a small trash can in it.hpoe this helps.
Jan 30, 2018 | Kenmore Elite HE4 Electric Dryer
Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite washer he3t model 110.4674 and the error code F35 keeps coming up. We did clear out the bottom drain pump, which had a lot of debris including toys, socks...etc. How can I clear the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^##
Jun 10, 2010 | Kenmore Elite HE5t Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
