Question about De Dietrich UMP404 Powerclean Stainless Steel Electric Single Oven
I have a De Dietrich oven, model sist1970. After turning on the oven and then raising the temperature knob, the main power breaker trips. Also, in the connection panel there is a red wire and a blue wire that are slightly burnt. Could this be a malfunction of the heating element? Thank you!
4 Suggested Answers
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
The part that needs replacing is the clock timer.
FIRST: ISOLATE THE CIRCUIT.
The front fascia is held on by three clips. Take off the two knobs and gently pry away the fascia fron the left, right and top centre.
The clock timer is held in by four plastic push clips at the top and bottom about 1cm in from the end. Push them in and pull the timer out.
There are now three wires on push clips attached at the back.
Do not take the colours for granted. On my oven just repaired the Live was Black and the Neutral was Red! The black marked 'C' is the input. The side by the trip switch is the output. The Red goes on the other side.
When the timer trips it causes the circuit between the input and output to break.
You have two options now:
Read the serial number of the timer and try and order it (expensive), swap the cables over.
Carefully run an electrical cable between the push clips on both black cables making sure you leave no exposed wire. Your timer and clock however will never work, the oven just does not care about it anymore.
Note: I am not an oven engineer, I am an electrical engineer in another field and have tested voltages and current and believe this to be safe. I have done this on my own oven.
Posted on Sep 16, 2011
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
How can I unlock my de Dietrich over door
Sometimes cutting power to it, either by unplugging or at breaker box, will resetbit.
Nov 08, 2017 | De Dietrich Ovens
I cannot unlock de Dietrich oven model ump504e1
Unplug the oven from power for 5 min to see if the lock will reset.
Nov 19, 2016 | De Dietrich Ovens
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
De dietrich oven thermostat
I would contact the company 's tech support and ask them if it is adjustable .
Feb 10, 2015 | De Dietrich Ovens
My de dietrich DOP770X4 oven won't stop beeping and it keeps turning on and off randomly
Try resetting it by the outlet it is plugged into, shut power off at the breaker/fuse box wait a few seconds then turn breaker back on.
Oct 11, 2014 | Ovens
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
good luck Andy B
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
De Dietrich UMP404 Powerclean Stainless Steel Electric Single Oven Logo
105 people viewed this question
Top De Dietrich Ovens Experts
richie46
ray gallant
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
