Question about DeLonghi DEC 180 E Dehumidifier
What does pf mean when its flashing ,dehumidifier dec 180e whont do anything now apart from flash pf?
Our dehumidifier seems to be working fine but the orange light is flashing above the star mark
When an error occurs, the Alarm lamp flashes orange. Check the status of the lamps, then take the appropriate action in Alarm Lamp Flashes or ON Lamp and Alarm Lamp Flash Alternately.
Jan 10, 2017 | Dehumidifiers
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
Indicator reads PF.cannot get it to run,any ideas
Your model Delonghi Dehumidifier has been retired. Therefore, no online manual is available. However, if you contact Delonghi Customer Support (1-800-322-3848), they can furnish one and answer the question about the PF error code at the same time.
Thanks for choosing FixYa.
Aug 11, 2011 | DeLonghi DEC 180 E Dehumidifier
What does "CF" mean when flashing on Kenmore dehumidifier?
MOST LIKELY CHANGE FILTER. MAKE SURE YOU HAVE INSTALLED THE CORRECT REPLACEMENT PROPERLY. LOOK IN YOUR OWNERS MANUAL FOR RESET INFORMATION.
Mar 02, 2010 | Dehumidifiers
CH1 IS SHOWN AS WELL AS THE BUCKET FULL LIGHT
I have a LG model LHD65EBL that first started icing up along the top edge during humid days. After several months of this, it finally stopped working and displayed CH01 with the bucket full indicator flashing.
I took apart the dehumidifier, removed the temperature sensor from the coil and rubbed it between my fingers. I then plugged in the unit and it started right up, confirming either a sensor or other circuit problem related to that sensor. For my model unit, I ordered sensor assembly #6877A30013L from RepairClinic.com for $21.75 + shipping.
When I received the assembly, I measured the new and old sensor with an ohm meter: new sensor = 5.5KOhms, old, defective sensor = 5.34KOhms. I installed the new sensor assembly and the unit is working fine.
Just because the bucket full indicator is flashing along with an error code does not mean there is a problem with the bucket full switch.
Dec 17, 2007 | LG LD65EL Dehumidifier
DeLonghi DEC 180 E Dehumidifier Logo
112 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
