Question about Little Giant WGP-65-PW 1/8 HP, 1900 GPH Premium Dual Discharge Pump, 16' power cord
My Little giant wgp-65-pw has been sitting idle in the water garden for a long time, how can i clean the alge from the intake.?
  • 56 Answers
I would suggest soaking it in a 5 gallon buckets of water with a cup or so of bleach added. This will kill all the algae and release most of it from the pump. Follow with a through rinse with water and you should be good to go.
Posted on Mar 24, 2011
My Little giant wgp-65-pw has tripped my gfi repeatedly. any idea why? No shorts in the cord are apparent
if a pump connected to a gfci outlet trips , then the gfci has detected a high resistance "shortage" inside pump and has disconnected power , this "shortage" can be nearly in detectable from human standards(shock) , but gfci picks it up
most likely pump seal has failed and water has gotten inside pump !! it only takes one drop to do this !!
Dec 24, 2012 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Problems priming little giant pw-95 pump
since this is a waterfall pump , id try using a short piece of dish hose and see how it flows water then , if it works there then id say your demand to lift is too great and a larger pump will be needed to lift that high ,
also note on waterfalls id leave out the ck valve on dish pipe , i know it takes longer to reprime itself each time , but that reverse flow action cleans your intake screen each time it shuts off
May 12, 2012 | Little Giant Wgp - 95 - Pw Pond Pump -...
I cleaned the screen, and the impeller is working however the little giant pump WGP is still not pumping water.
You may need to take the bottom of the pump apart and check to see if any thing has gotten through the screen and clogged the impeller.
Nov 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Little Giant pump WGP-90-PW trips GFI circuit
You might have 2 problems. The GFIC might be wired wrong or the pump wirng might be compromised with moisture. The noise issue? Are you running this unit without submersing it? They will burn out if you do. To get a more accurate running sound, submerse it with a flexible pipe so you can run it in a 5 gal bucket without losing the water.
It's possible a bearing is burned out.
Ron
Jun 10, 2010 | Little Giant Plumbing
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Little giant pond pump wgp-65-pw turn it on and it runs for about 1 min. then shuts off for seconds and then back on for a min.
the magneto has gone in the pump,replace the pump as its cheaper than the repair would be.
try a hoselock pump
Dec 20, 2009 | Garden
Anthony filter system faulters after short while of running
If you have alge in your water it builds up in the filter and stopps it up rite away. You will need to take the filter apart again and hand clean it out again. but you will need to super chlorinate the water and kill all the alge before you start the pump or it will plug again. If you run it like this for any amount of time it will crush the grids, so be sure you kill all the alge.
Oct 13, 2009 | A.B.S ALADDIN GO-KIT #7 ANTHONY POOLS 2"...
Little Giant WGP-65-PW 1/8 HP, 1900 GPH Premium Dual Discharge Pump, 16' power cord  Logo
159 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
