Question about Whirlpool Washing Machine Knob - 3362624
I have a front loading washing machine with many symbols and no mnaul. Is there a key you can give me to tell me what the symbols mean? Thanks
Go to back of washing machine and look for label with model number and serial number.
Take a photo so the numbers are easy to read.
Then search for example: Maytag RG3455 .pdf
Be sure to include .pdf in search parameter.
Another approach is to contact repairclinic.com and see if they have schematic or manual.
Also re-post question at fixya clearly stating your brand and model number to see if someone has a link or has a manual.
Better results at fixya might be available when offering $3-5, since somebody has done work to find and post manuals for your benefit.
Posted on Apr 10, 2011
Washing machine 12401td front load-on its digital screen tells m
hello,
what this means is that
The "oe" is an error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
an also means indication that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you need to do to fix up this problem is to do what is call general clean up on it by unscrew the key (stroll) and then clean the dry and any form of water in then make sure that all wire are well connected to the position.
Good lock and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Got the Bosch Classixx 6 1400 Expresswashing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
May 14, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Bosch classixx 1400 express key symbol
Apr 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 Express 1400 washing machine cant
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Refusing to start cycle. key symbol flashing and a beep
Hol d the start key down for around 5 secs and it will remove the lock. Release the button and press start and it will work again.
Jan 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Whirlpool Washing Machine Knob - 3362624 Logo
174 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
