Question about Keurig B66 3-Cup Coffee Maker
My B66 will not allow anything to come out of the dischare side, tank and water valve on supply side are all clear and De-scle mode is showing and started De-scle procedure but it will not discharge anything during this or any type of procedure
  • 40 Answers
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Posted on Mar 29, 2011
We added anti freeze into our water hold tank. There is a pink film on the bottom of the tank. How do we clean the film out of the tank?
problem is there is an RV for your system. you will need to do the following.
Drain all holding tanks, fresh water and sewage
  1. Attach garden hose to fresh water fill and fill tank.
  2. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side.
  3. Flush toilet until clear water runs into bowl.
  4. Dump tanks again.
  5. Sanitize water system. use a water sanitizer
  6. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter.
  7. When ready to use the water heater, turn by-pass valve to open position to allow water to enter and fill the hot water heater tank.
May 10, 2017 | RVs
What to do when my hot water heater smells like rotten eggs
This is for electric water heater:
Flip the water heater breaker off in electric main.
Shut off water to the heater. If there is no valve on the cold supply side, then you will need to kill the water to the whole house.
Attach a water hose to the bottom outlet.
run the hose outside so the end is lower than the bottom of the heater.
open the valve on the bottom outlet.
The water in the heater will start trickling out and bringing sediment with it.
Once the water stops flowing, turn the water back on. This will refill the water heater, flush more sediment, and rinse the tank out. Allow it to run until the water runs clear, if stained.
Close the drain valve, disconnect hose, turn power back on.
If the problem was due to deposits in the water heater, this flushing should remove the offending materials and odors. Good luck!
For Gas, do the same thing except turn the gas down to pilot only or vacation mode while flushing instead of shutting off a breaker which the gas heater will not have.
Apr 30, 2014 | Nikon Coolpix S9100 12.1mp Digital Camera...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
The black cap inside the toilet is leaking? Is there a seal? How do I remove the cap?
If the black cap you are referring to is a tank bolt, then follow the instructions as follow:
If you cannot tighten them, then they will need to be replaced. Turn off the water supply valve, flush the toilet and bail out as much residual water as possible. Remove the old bolts and separate the tank from the bowl. Replace the old tank gasket and refasten the tank with new bolts, properly placing rubber washers symetrically. An added precaution that I use is (after drying the inside of the tank well) is applying a dab of clear elastomeric sealant to the top of each bolt head, working it past the edges of the bolt heads onto the tank. Allow the sealant to cure as per directions. Open the supply valve slowly and allow the tank to fill. Inspect the tank bolt holes for leaks
Nov 25, 2010 | Eljer Home
The black cap inside my toilet is leaking. Is there a seal? Does the black cap come off?
If the black cap that you are referring to is a tank bolt:
Nov 25, 2010 | Eljer 141-0220-00 Toilet Tank White
My tank bolt holes are leaking
If you cannot tighten them, then they will need to be replaced. Turn off the water supply valve, flush the toilet and bail out as much residual water as possible. Remove the old bolts and separate the tank from the bowl. Replace the old tank gasket and refasten the tank with new bolts, properly placing rubber washers symetrically. An added precaution that I use is (after drying the inside of the tank well) is applying a dab of clear elastomeric sealant to the top of each bolt head, working it past the edges of the bolt heads onto the tank. Allow the sealant to cure as per directions. Open the supply valve slowly and allow the tank to fill. Inspect the tank bolt holes for leaks.
Nov 23, 2010 | Toto Aquia II Dual Flush Toilet
Draining the Priemer Plus Gas Hot Water Heater
Begin by turning off the gas at the tank and at the valve near the tank. CAUTION: Do not proceed any further if you do not know how to relight the gas pilot!
2) Turn off the COLD water supply to the tank.
3) Attach a garden hose to the drain valve at the bottom of the tank. Run the hose to a convenient drain location. Be careful if you use a real cheapy garden hose... some of these become very soft when hot water runs through them, and may leak! If you don't have a drain in the basement floor or suitable sump hole, you have my sympathies... this drain-down can take a while with a bucket! Oh... and be careful if you use a soft plastic bucket. It can also soften from the heated water so don't overfill it or burn yourself!
4) Open up the hot water side of any faucet. Open up the drain valve on the tank and allow it to empty. Miller time. That is, unless you don't have a sump...
NOTE: If the drain valve clogs, turn on the cold water supply to the tank to use water pressure to "blast" through the clog.
5) When the tank is empty, shut off the drain valve and turn on the cold water. This will loosen up more sediment in the tank through the churning action of the cold water in the tank. Let the tank fill partially and drain it again. In fact, if you find that the sediment starts to clog the drain valve, turn on the cold water supply to the tank, which will help loosen the sediment and blast it out.
If you have extreme amounts of sediment, you may have to repeat this procedure a few more times. Look at the drain water... if it is running clear, you are done. Shut off the drain valve, open the cold water supply and allow the tank to fill. Once water comes out of the hot water faucet, the tank is full and your task is done! Now, you can turn the electricity or gas back on to heat the water.
How frequently to clean the sediment from your tank...
This depends on the source and purity of your water supply. Some pros recommend doing it annually, some every few years. I would recommend doing a partial drain down annually if you find any sediment in the tank, otherwise every couple of years.
Remember that with an electric water heater, you must turn the power off! Even a partial drain down may expose the upper heating element to the air and permanently damage it!
Jan 21, 2009 | Water Heaters
Ventilate will not disappear from the display,and the machine wont work
the procedure is filling water tank opening side valve that should clear the ventilate if is still there remove water tank apply water pressure with pump in the hole of water tank let me now pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
No Water
there may be a few things causing this, a blocked supply/transfer hose in the base, a blocked meter tank at the side of the dishwasher, turned off water supply, a faulty water valve,the unit is in "flood mode" and has a leak in the base and will not allow any more water in(check by tipping the dishwasher 45% sidewards to see if water leaks out or the water is coming in but you are not seeing it because the wash motor is jammed or seized.
Jun 22, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Keurig B66 3-Cup Coffee Maker Logo
125 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
