I have Konica minolta Di2510 and I think I have firmware problem, but am not sure. After I tried to configure network Scanner. only thing I change is the IP address and enable the HDD from the menu (but am not sure that the machine has a HDD) after I reboot it the firmware doesn't loading and keep rebooting by it seft. Is there a chance to fix this and is it possible to download firmware from internet because I can't find.
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
  • 207 Answers
SOURCE: how can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
Posted on May 20, 2008
  • 47 Answers
SOURCE: Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Posted on Jan 06, 2009
SOURCE: Cannot find server or DNS Error
erool
Posted on Jan 24, 2009
Kevin Hayes
  • 167 Answers
SOURCE: I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Posted on Feb 17, 2009
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
Sep 02, 2014 | Konica Minolta Dialta Di2010 2510 Toner 2...
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
How to solve error c0650 on minolta di2510
Did you changed the home sensor? If yes, is the sensor working properly? Try the sensor function in Service Mode.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 18, 2014 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub C252 FTP Scanning Problem
I'm not sure what you want to do, but I have installed various BizHub machines.
User ID, is exactly what it is... Used to monitor and manage individual users.
Which OS is the machine you want to scan to?
Depending on machine, I will hint Konica Minolta FTP Utility...
Mar 04, 2014 | Office Equipment & Supplies
Konica Minolta bizhub 224 network connection
u have to configure network settings of machine and then try
Jan 07, 2013 | Konica Minolta Bizhub C224 Color Copier...
KONICA MINOLTA Di2510 driver for window 7
Can not use windows 7 on that machine legacy Minolta best is xp,2000 or 95 Self Help Product Support Konica Minolta Business Solutions Inc try this
Apr 29, 2012 | Minolta Di2510 All-In-One Laser Printer
Cannot access to the scanner page
Your laptop is not configured properly to the network. You forgot to mentioned what type of scanning. ftp, smb, scan to email scan to box. But any way your IT can help you with this problem. If not I will email you the step by step to configure you laptop.
Jun 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Open Questions:
How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 22, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
199 people viewed this question
Alun Cox
David Payne
David Payne
