At the end of the wash when it is supposed to spin it comes up with E3 i have a nec nwtl456
    Brigadier General:
  • 6,277 Answers
(try this first!)
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 24, 2011
My nec nwtl456 washing machine wont empty all water when spin complete anoying is it the pump or?
Can you hear the pump motor running when you first turn the program on, or during the spin cycle? a sort of glug glug noise when the drum is NOT turning. If you can, but the water is not draining, you have a blockage somewhere. If no glug glug then the pump is seized with a coin or pin etc and must be removed and freed or replaced.
Check any filters fitted first; remove and clean them. Lower the grey drain hose onto the floor - does water run out? if not, blockage maye be in sump hose or pump chamber (sock, etc)
If it does run out, blockage will be in connection to sink / waste pipe on your domestic plumbing.
Feb 03, 2018 | Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
My haier washing machine with error code E3,what 's the problem?
Can you help me to fix my haire plz it not spin
Nov 11, 2011 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
The spin cycle will not run on the regular wash. Once the switch points to the SPIN, the noise is present, but there is no movement within the washing machine. The dial continues to move until the supposed...
Check the pump drive belt. It may have come off.
Sounds like the motor is spinning but the pump belt isn't spinning the pump.
Pull the front cover and look under the machine for the belts.
K
Jul 09, 2009 | EuroTech Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Wash machine says E3
not sure where you can get a manual but sometimes blankets produce a lot of fluff while washing maybe the pump filter needs cleaning out the machine will not reach speed with too much water in it
Nov 11, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
