Question about Sony Dual Shock 3 Controller for PlayStation 3
My ps3 pad will not stop vibrating even when i turn it of
    Novelist:
  • 102 Answers
Toggle the vibration function on the controller (turn if off then on again). You can do this by holding down the Playstation button in the center of your controller. Then select "Controller Settings" and switch the "Vibration Function" to off. Exit out and repeat the steps, but this time turning it on.
You could also try to reset the controller. There's a little button in the controller on the backside at the top; it's near the L2 button. You'll need a paper clip in order to reach it. Press it, then reconnect/re-pair your controller to the PS3 (you know, hook it up via USB then hit the Playstation button).
If there's still problems just let the battery drain; hopefully it'll be sorted out when you charge it back up.
Hope that helped!
Posted on Mar 25, 2011
Truck shakes when brake is applied upon slowing down it gets shakier until i let off the brake and pulse the brakes till truck stops
A common cause for the vibration when braking is when front brake pads are replaced, but the brake rotors were not resurfaced smooth. Overtime when braking, the new pad will wear into the rotor that was not cut. The uncut rotor, having high and low spots when turning, will cause the brake pedal to vibrate/pulse when stopping.
Sep 16, 2011 | 1998 GMC Sierra
My DS3 (for the new PS 3) lights are always on (all 4) but won't respond at all, when I tried to charge it, it kept vibrating non stop and still won't do anythng at all. What should I do? try to...
First you should turn off your ps3 and then take out your plug for safety resons. secondly shake your pad there is a reason but a weird one. third, get a pin look at the back of your pad and clik that tiny button. then put the charge wire in your pad put your ps3 on. wait 5 minutes that should work.
Aug 17, 2011 | Sony Dual Shock 3 Controller for...
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Vibration when stoping in brake pedel
probably not mechanical. i'd check into the anti-lock sensor.
Apr 25, 2009 | 2003 Jeep Grand Cherokee
Ford 1988 escort GL-Front wheel constant scrape-scrape,vibration
sounds like you need new brake pads and the rotors atleast turned down if not replaced
the pads should stop the noise and the rotors should stop the vibration/wobble
thanks wes
ps please rate me
Mar 27, 2009 | 1988 Ford Escort EXP
Controller problem
if u check your power save options they r probably set so the j-pads turn off if inactive for so long, changing the setiing should sort it
Dec 21, 2008 | Sony Playstation 3 (PS3) Console
CECHZC1E -Wireless Controller
the standard Sonuy cotroller does not have vibration.
There is a new one on the market (can't recall the name right now also made by sony). Runs about 75 dollars.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
My brakes grind and vibrate when pressed
My feeling is that you did not use a high quality pad like the Bendix or wagner thermo quiets and the rotors likely need surfacing even if they are new they can be warped due to the way they are stored. Good Bendix pads for this vehicle retail for around 75.00 or more
Aug 27, 2008 | 1999 Ford Explorer
Sony Dual Shock 3 Controller for PlayStation 3 Logo
151 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
