Question about Garden
I have a Suffolk Punch 35s mower and the petrol cap leaks badly and won't stay on whilst mowing, do I need just a new cap to fix it?
    Sergeant:
  • 250 Answers
Yes, that's all you need. At some time yours was cross-threaded, That means that it was forced on wrongly, and broke the thread.
Posted on Mar 24, 2011
How much oil in a Suffolk punch 35s
Geoff, Check the attached links, manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.oldlawnmowerclub.co.uk/sites/default/files/opmanual/Suffolk%20Punch.pdf
Suffolk Punch OWNERS MANUAL
Small engine repair How to drain and change the oil in small petrol engine
Jul 02, 2016 | Garden
I have a Suffolk punch 14 s with a Tecumseh engine model number AQ148 when I turn off the throttle petrol leaks out of the air filter please could you tell me how to fix the problem. Many thanks Neil
If engine runs fine and thats only problem the quick is a fuel shut off valve install and turn gas off before shut engine off or I think it is fuel float in carburetor that will need to be set or replaced.
Jun 16, 2015 | Tecumseh Garden
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
I need to set up the dellorto carb on the 35s suffolk punch
Running only with full choke is a fuel problem. Unhook fuel line from carb. it should run good. If not go back the line. Check the fuel cap vent.
Mar 25, 2014 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
I cannot start my Suffolk punch 43s petrol mower, can anyone tell me how the choke should be set?Or where can I download a free instruction manual.
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Sep 18, 2009 | Garden
Maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Sep 14, 2008 | Garden
Garden Logo
306 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
