Question about Bosch WBB24759GB Washing Machines
BOSCH WFFF2000 WASHING MACHINE DOES NOT SPIN - Bosch WBB24759GB Washing Machines
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 24, 2011
How do i get a brand new bosch washing machine to spin out the washing. it does not spin out my washing the clothes are dripping wet
Hello, Kathleen -
Since your Bosch washing machine is new (and therefore under warranty), I suggest you call the store where you purchased it and ask them to send a repair technician to check your machine. Some internal mechanism may need to be reconnected because it was shaken loose in transportation to your home.
Dec 20, 2017 | Bosch Washing Machines
Why won't it start?
Bosch WAS32461GB Washing Machine that will not start
www.how-to-repair.com/.../bosch-was32461gb-washing-machine-that-w...
Mar 31, 2015 - Bosch washing machine Will not start, won't start, Will not open - this is usually due to the machine still having water in it or a door interlock ...
My Bosch Washer Won't Start ' eHow
www.ehow.com > Home
If your Bosch washer does not start, there are a few troubleshooting steps to take before calling for ... Problems with Bosch washing machines that won't spin.
Bosch washer WFMC6400UC won't start - Appliantology.org
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 07, 2016 | Bosch Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Bosch washing machine won't spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Oct 26, 2008 | Bosch WFK 2401
Bosch WBB24759GB Washing Machines Logo
70 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
