Question about Samsung CLP-660ND - - colour - laser - Legal/ A4 - up to 24 ppm / up to 24 ppm
I need to replace a Samsung CLP-660 pick up roller and need the part number if you can help. Thank you
Look on the website www.MK-electronic.de. Find the printer model and look at the various pictures until you find the one which matches your part. Beware of inconsistent parts usage by e.g. Samsung.My Samsung printer has a different paper pick up roller to what they specify as the correct part. However I can find it in the MK list of parts under a different part No and model.
Posted on May 17, 2011
The paper keeps jamming in our Samsung laser printer 660 nd. We bought heavier paper for a laser printer but it still jams.
The ideal paper is around 80 GSM (gm2) if you are having problems with a BRAND NEW REAM of standard copy paper then your printer will need service.
paper that is thicker/heavier than this can actually cause more jams and problems and show worn out rollers earlier
These printers only tend to jam at the entry (pickup) near the base of the printer or in the fuser unit (hot area near the top)
if you are getting jams in multi page documents, have a look at which area the most crumpled piece of paper is in before you try and remove it.
the pick up rollers and separation pads are relatively cheap but the fuser units can be a bit pricey.
CLP 660ND CLP 660ND XAA Support SAMSUNG Canada
Sep 29, 2014 | Samsung CLP-660ND - - colour - laser -...
Samsung CLP-300 printer not printing, the paper tray will not pick up the paper.
Often the rubber pickup roller is either worn or dirty. It is located just above the paper tray. Use a damp cloth and try to cleaning it, sometimes that helps. Otherwise you will need to replace the roller.
Jun 16, 2011 | Samsung CLP 300 Laser Printer
How do you get the Tray 1 pick up roller out of the Samsung laser printer model CLP660ND.? I need to replace it
This is the easy bit:
Turn the printer over so that you can get at the bottom. Remove the tray and the roller simply slides off.
Slide the new one on and you are sorted.
The only problem is that the Replace Pick-roller message will not go away! There MUST be a way of resetting it, but nobody who knows how to do it, is letting on how!
May 12, 2011 | Samsung CLP-660ND - - colour - laser -...
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
Transport rollers need to be cleaned
The transport rollers in the Samsung CLP-300 can not be removed and are hard to even access. You can print several 20-30 pages through and let the paper clean it or If you can get into them, you can try cleaning the rollers with isopropal alcohol, but there are snap-locks that can break in the process of dismantling it and it's so hard to get into it the guts properly, that usually it really isn't really worth the effort. Samsung claims that the roller is useful for 50, 000 pages but I have printed less than 500 pages and had it just start leaving streaks.
Mar 02, 2010 | Samsung CLP 300 Laser Printer
Printer does not pick up paper
Good day keefer, maybe you have a technical problem with your printer. It seems that the feeder parts inside your printer needs for repair. You can go to your nearest technician in your area to solve it for you.
Hope this help.
Dec 18, 2009 | Samsung CLP 300 Laser Printer
My samsung clp 300 won't pick up the paper
I used to have the same problem.
Levelling the paper tray helped to solve it.
Make sure the printer + paper tray stands on an equal levelled surface (on which the tray doesn't hangs over the surface)
Nov 10, 2008 | Samsung CLP 300 Laser Printer
Paper jamming and misfeeding
misfeeds usauly mean worn pick up rollers. this can also cause the jammin of the paper as well if the paper is not folliwing the path correctly due to being picked from the tray at a different angle top nonmal. if you let me know the makeand/or model number of your printer i will try kfind the part numbers for you
Hope this helps
Pete
Nov 05, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-660ND - - colour - laser - Legal/ A4 - up to 24 ppm  / up to 24 ppm  Logo
445 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
