Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I Have a Toshiba Regza XV55, purchased in December 2008 and the manual on/off switch has been temperamental for a few weeks until last night when it stopped working completely and now we can't turn the TV on at all. Can you suggest anything
    Sergeant:
  • 261 Answers
I suspect that the switch has a fractured solder connection or that it went bad all together..The only real way to check the switch is to take the tv apart and check it with an volt ohm milliameter. If it feels like it is not clicking then most likely the switch is bad now. But if it feels like it is working correctly it is most likely a fractured solder connection and needs to be re-soldered, The only other variable would be that the connector is broken or that it just came unhooked. That would be an easy fix. Good luck. HDTV GURU JAY.....
Posted on Mar 24, 2011
Purchased Toshiba Regza 32AV615DB December 2010. On several intermittent occasions sound disappears and continuous buzzing noise takes over. Picture still on screen. Only way to rectify is turn TV off...
Sound carrier frequency are quartz locked in all modern TV. Your TV's sound freq: seems to be drifting. In the station tuning setup it will ask you Region ( Country ) Have you chosen correctly ?.
Mar 09, 2011 | Toshiba Televison & Video
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Hi how do you coonect your toshiba XV55 LCD tv to your laptop
Hi you need to use either a hdmi or rgb lead to connect laptop to your tv please give thumbs up if this helps thanks
Feb 13, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Apr 06, 2010 | Televison & Video
Toshiba Regza lost swivel stand bolts
if your GF wants you to separate the three in one coffe what well you do?
Jan 11, 2010 | Televison & Video
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
5a01 code 08/01/2009
I used the same codes from December on my box last night and they worked Here they are Give it a go
5A 01
00 - E7 D3 69 2E 6F 38 EA 78
01 - E8 C9 E5 6E B0 49 53 F5
Jan 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
Yellow light blinking - blank screen - won't turn on
The problem is with the signal board. Basically, it is not allowing the power signal to go from the on button from the set or the remote to the TV. I am having the exact same problem with my 42" LCD Regza. Currently, if you are under warranty, Toshiba does not have these in stock. They will not have them available to send until early January. My TV has been at the repair shop since December 4th. I am very upset as I won't be able to watch the bowl games in HD. If your set is still under warranty then call Toshiba help line at 800-575-5469. You will need the model number of yout TV that is listed on the front of the owner's manual. They are:
27HL67
32HL67
32HL67U
37HL67
42HL67
The first number will be the giveaway as to which model you have. It is the size of your set. They will ask you to try a hard reset. (Hold pwer button down for 5 seconds until you see the yellow light go solid and go off.) This will most likely not work. If it does, you are lucky. I found that if you unplug the TV for an extened period of time, ie overnight, ity may come back on. It will eventually give out completely though. Better to get the problem addressed with the manufacturer. If you are not under warranty then I do not know what to tell you. Right now I am searching the internet to see if I can find this part to maybe purchase myself. Only if it is not too costly. If I find anything I will post here for all. If you have any questions, feel free to email me a wkjtx@hotmail.com and I might be able to give you more details on your problem. Good Luck.
WJ
Sep 23, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Which lead do i need
get a pc cable from your local computer shop serial port to serial port and bobs your uncle
Mar 23, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
296 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
