Question about Haier RRTG21PAB (207 cu ft) Top Freezer Refrigerator
Water in front of frig in floor, good size puddle usually in morning not leaking alot but over night can not see anything under except at front
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
I keep walking into my kitchen to find a strange little puddle of water near the front left of the fridge. cannot find a trail from under the fridge so i have no idea where it's coming from. is there a pan...
could be the defrost pan / ck it for crackes / some times it's the water valve leaking through . due to water pressure changes . put a paper towel in disp and see if it gets wet at night . and if you have a large dog that drinks from it at night this also could be the problem ( ha ha // ) but it has happened .mm
Apr 18, 2010 | Refrigerators
Finding a puddle of water each morning under the left front of frig--does not leak during the day?
YOUR DRAIN IS CLOGED.LOOK AT THE BOTOM BACK PORTION OF YOUR FREEZER. (INSIDE) WHEN YOUR FREEZER GOES INTO DEFROST THE WATER HAS TO GO SOMEWHERE. IF THE DRAIN IS CLOGGED IT WILL FLOW OUT THE FREEZER DOOR.
Mar 16, 2010 | Refrigerators
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Water dispenser leakage.
I had a customer that had the same problem with is water dispenser on frig . he replaced the water valve / but it didn't help / so he replaced the dispenser control still didn't help . this only hapened during the night . so he set up his cam coder for over night and you know what he found . in the middle of the night his dog would get a drink and dribble all over the floor . . i don't think this is your problem . but you never know . **** . . no easy fix .. ****
Jan 06, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
I think the water pump is leaking. the car gage doesnt go over the driving temp but i smell fluid ive checked the hoses it just came up about 2 in low of fluid i added and now there was a puddle under the...
When you start the engine look at the water pump and see if engine coolant is pouring out the weeping hole.If so you need a new water pump.Use a light source to see this
Oct 08, 2009 | 2005 Cadillac CTS
Water accumulates and freezes at the bottom of our freezer. Once the bottom of the freezer has formed a slab of ice the water eventually drains out of front of freezer and leaves a good size puddle on our...
your refrig. goes through a periodic defrost cycle whereby this water is produced. It is supposed to travel down to the evaporation pan near the floor of the frig. Your evaportation pan may be clogged, remove the front lower panel and get a flashlight and examine it., or the tube leading from the freezer floor may be clogged or have ice it it. Check that out and if the opening of the tube has ice in it, melt it with a hair blow dryer
Oct 06, 2009 | Refrigerators
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore side-by-side 106.52764100 Frig leaking water
Do you have a Dog ??? I had a customer who had a problem like this once.................Only to find out in the middle of the night the dog jumped up and with his nose pressed the water dispenser..If not plz check inside the freezer and see if your drain is clogged pull the bottom drawer out and look on the back wall..
PS: the pan even with a clear drain will not fill up the condenser fan with the heat from the condenser will evaparate the water after a defrost cycle
Feb 23, 2008 | Refrigerators
Haier RRTG21PAB (207 cu ft) Top Freezer Refrigerator Logo
16 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
